3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Cooler
USB Cooler
Step 1What you need
what you need
motor, (port USB = max. 2,5W !) 2 Cd, USB cable, papier or plastic tube
66 comments
1-40 of 66next »
Apr 21, 2011. 1:11 AMmingus15 says:
hello,
can some help me?!
how to make the cd past in that angle?
did you remove them and atacht them again with glue?
bb
Aug 13, 2011. 2:24 AMuberdum05 says:
I once saw a method where you cut the CD as shown above and then you can heat the part where the cuts meet and then just gently twist the blades :)
May 8, 2011. 11:05 PMadrian09 says:
are u german?
Apr 16, 2011. 12:30 AMtobyscool says:
nice fan i am definitely going to make one while its summer here :D
Jul 15, 2010. 12:36 PMS5114 says:
What's the orange thing in the 2nd pic.?
Jan 18, 2011. 12:07 AMjackh94 says:
it's just a connector, wires get put in both sides and the screws lock them in place
Feb 21, 2010. 10:34 PMsmart_thingup says:
 i've done make this cool fan,.. thank you,...
Mar 1, 2008. 4:47 PMjohnnyboi says:
where would i get the small motor?? from a old tape radio? im still not sure how you do the wiring and if you really need to solder it... im stll a beginner
Mar 1, 2008. 5:13 PMhock3ydud3 says:
radioshack has a bunch of them for $3 to $5 and something like a tape player or old hairdryer or something like that would work
Apr 17, 2008. 5:23 PM=SMART= says:
god dammit i wish we had radio shack in the uk
Nov 15, 2009. 11:44 AMlinuxthefish says:
i wish we had one too! :)
Apr 18, 2008. 2:59 PMlifelong-newbie says:
Me too. Next best thing is Maplin for high street components, but they are expensive and no where near as common as Radioshack. My nearest is brighton, 13 miles away. a 20 min train journey to buy a resistor, not gunna happen.
Apr 18, 2008. 4:31 PM=SMART= says:
lol yea maplins is a bloody rip-off, i just get what i need from my DT department at lunch break when there's no-one around, not a very big choice though, switches, leds, and motors nothing special.
May 11, 2008. 5:00 PMweretater says:
Is there any easier way to cut the cd? because every time i tried, it kept fracturing, making that blade worthless.
Jul 12, 2009. 1:55 AM555mst555 says:
u can use a scicors....just use a sharp one....blunt ones make the CD crack
Apr 20, 2009. 1:20 PMbassmasta1010 says:
get someone to blow on it with a WARM NOT HOT hair dryer and cut it with scissors or watevr youve got....
Jun 29, 2008. 8:12 AMBartboy says:
Exacto knife
May 17, 2008. 1:57 AMpower says:
by using cutter,slowly cut it.the best way
Jan 3, 2009. 12:39 PMPulha says:
erm... i did all exactly as it says in the guide but when i put my fan in usb, it works but my mouse turns off -.-
Aug 10, 2008. 10:38 AMCalcProgrammer1 says:
How are you supposed to bend the blades? I cut 8 sections but they won't stay angled after I bend them. Oh, and if you do this with CD-R's, you'll get flakes of shiny reflective paint everywhere.
Dec 22, 2008. 11:00 AMcowscankill says:
Use the candle to melt the blades a little at the base
Nov 5, 2007. 12:43 AMimnotniko says:
thats really kool. where can i get a that little motor from though?
Oct 27, 2008. 6:48 AMimshanedulong says:
A dollar store car.
Oct 24, 2008. 9:44 AMticky2143 says:
take apart an old r/c car
Aug 31, 2008. 2:46 AMtubbychick3n says:
also if you have an old cd player, if you taek it apart, you can get a motor out of it that has a spot that lets the cd snap right in. it's the part that you actually put the cd onto.
Apr 20, 2009. 1:17 PMbassmasta1010 says:
oh yeh i broke open a old cd player that sukked and i found 2 or 3 motors, wire, switches, capcitors, and a lot of stuff
Apr 22, 2009. 4:08 PMtubbychick3n says:
Yep. They're actually quite useful for electronics of all levels. The one i opened even had 2 audio connectors that i plan to use for an amplifier.
Aug 20, 2008. 5:36 PMshammallamaman says:
Radio Shaq, they sell them relatively cheaply
Nov 17, 2007. 10:41 AMy0urm0msname says:
you could always get it from an old optical drive http://www.instructables.com/id/USB-Cooling-Fan-from-a-broken-drive/
Mar 7, 2008. 1:04 PMn0ukf says:
I just sttripped down a CDRW to see what usable parts I could find in it. For this project you'd likely have to use the tray transport motor, since both the head and disc drivers were stepper motors and need a specific pulse stream on 2or more sets of windings. Though a cheap stereo system (radio/tape/CD) I stripped a while ago had a regular DC motor for the disc instead of a stepper. You just have to see how they're connected (2 terminals are simple, just add DC).
Apr 3, 2008. 9:42 AMkillerjackalope says:
It's only the CD writers will have a stepper, reader only just has to turn away so it's almost always DC motor...
Aug 20, 2008. 4:05 PMMetaferia says:
hi, what did you put in the cd hole? so you can glue it with the motor?
Aug 20, 2008. 4:54 PMshammallamaman says:
It looks to me like a cork
Aug 20, 2008. 5:25 PMMetaferia says:
ok, thanks, i will try it
Aug 20, 2008. 5:34 PMshammallamaman says:
No Problem
Aug 20, 2008. 5:01 PMshammallamaman says:
Very nice, I like the way you think
Aug 12, 2008. 11:28 AMjetsmiley123 says:
i cut a little material out from in between each fan blade to give it some room to suck some air in and it prevented it from fracturing when bending it over the flame. here's a picture of what it looks like,
Jun 4, 2008. 10:39 AMNunavutnewsrules says:
I think i will make one of these but i will add a wire cage to it. Yea i like my fingers and knowing me i would accidently put something important behind it and it would be destroyed.
If you have knex, that whould be VERY simple
Oct 22, 2007. 6:24 PMLinuxH4x0r says:
now I know what to do with the aol cds!
1-40 of 66next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
104
Author:msolek
