3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Cord Shortening
USB Cord Shortening
Shorten a USB cord (or any cord) without cutting it.  Use this shortening technique to organize and manage electrical cords.  Need it longer in an instant? ...no problem... pull the cord and its back to its original length.
 It is a quick, and easy method to permanently or temporarily, shorten any cord
and best of all... it does not required anything other than the cord itself; no metal twist ties or plastic zip ties!
The cord is shortened by using a series of slip knots (also known as a crochet chain stitch). The stiffness of the cord holds the slip knots in place but a locking tuck at the end will ensure the knots will not come undone.
But, if the shortening is temporary...skip the locking tuck, and a tug on the cord unravels the knots for use of the full cord length in an instant.
Use it  to manage charging cords...it will extend in a second to use the device while still plugged in.
Step 1Spagetti
Spagetti
I don't know much about the electronics involved with USB ports but, I do know that you can use a good old Mechanical knot solution to keep those cable vipers from tying themselves in unintended knots
Most of the time the devices used with a lap top are only a couple of inches away and all the extra cable spills around (or off) the table.
With this solution, a 5 foot cable can be shortened to about 1foot (using 1" dia. loops)
(And don't worry the pesky electrons don't seem to mind the twisted path.  They still manage to find their way back and forth.)
11 comments
Jul 6, 2010. 3:42 PMElChick says:
Great Instructable. I've actually been doing this for years with some of my own cable management. A couple of comments - this is actually doing a chain sinnet knot, which is the same thing that is done in crochet! (Just as an interesting side point.) More importantly, be careful of the loop size. I have done this with powercords, usb mouse cords, and headphones (among other things), and the size of the loop is important!! I have done some with the loop being very tight and small, and after a few weeks undid it because I needed the longer length again. The cord was irreparably kinked into the loop shapes and could not be straightened again unless kept taut. It kept reverting back to the tortured loop shape I had put it in with the sinnet. I would think that loops that are bigger and looser would not lead to this problem, but keep that in mind as you try this method out. Also, a pair of earphones that I did this to eventually failed. But again, that might be because I had a very tight chain sinnet or possibly because of the harsh treatment I gave them while working as a stocker unloading trucks of heavy boxes. The exact reason for failure is unknown, but something else to keep in mind. Other than that, great 'Ible and great way to manage cables on a temporary basis!
Jul 6, 2010. 4:07 PMElChick says:
I just reread the 'Ible again and noticed that you already mentioned the crochet stitch. Sorry! lol
Jul 6, 2010. 4:10 PMElChick says:
And again noticed that you mentioned the kinking problem. Again, sorry. I'll just keep my big yap shut. lol
Nov 6, 2011. 12:25 PMuberdum05 says:
To solve the kink problem, try stretching the cord straight and taught and then gently heat it with a heat gun or a hairdryer :)
Oct 4, 2010. 11:31 PMbustatech says:
Another guide on how to shorten the USB cable for a mouse: http://www.bustatech.com/shorten-the-length-of-wire-for-your-pc-mouse/
Jul 15, 2010. 10:19 PMgeocrasher says:
This has proven very good! I've helped a few of my clients using this. It worked great today for a gal who had a regular mouse on her laptop. The cord was way too long. Six or seven large loops later, the cord was tamed. Nice work!
Jul 10, 2010. 8:37 AMstarrymirth says:
Cool idea. And a well illustrated and explained Instructable! Just a note to be aware of: as soon as you curl insulated wire into loops you get an inductor. Inductors use magnetic fields to try to oppose current, which can have some unwanted side-effects. If you're running a high current device (think heater/iron) the heat generated by the inductor can cause the insulation to melt. :) We had this happen to an extension cord which was left coiled up while my dad was using it. My physics lecturer was telling us about his ionospheric research in the Antarctic: the sensitive equipment had a large number of wires. A new guy took over and after a few weeks the equipment stopped working. They had to sail my lecturer back there to figure out what was wrong, and when he got there, every wire had been neatly coiled up, and it prevented the equipment from working! :)
Jul 8, 2010. 8:43 AMMoritzB says:
this knot is called " chain stitch"
Jul 4, 2010. 8:12 PMcraig3 says:
This might unravel the shield inside of it, but its still good, it leaves lost of open area for air to get to it and cool it down if needed unlike other techniques ive seen, i like it
Jul 6, 2010. 12:30 PMwkter says:
I've never hear about an USB cord ever needing to cool down unless you short circuit it...
Jul 6, 2010. 6:53 PMcraig3 says:
Maybe thats just big audio cables then
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
609
Author:hpstoutharrow
