I'm going to build a USB Easy Button. I found most everything I needed from jro's project and a flickr photoset by tommybear. Plus, I've been dying to try one of these U-HIDs. I also describe this process on my blog.
What you'll need:
- An Easy Button (or Boton Facil if it suits you better) $4.99
- A U-HID Nano and USB Cable (with shipping) $42.00
- A Modular Harness for the U-HID (optional) $9.00
- Soldering iron & solder
- Wire (if you didn't buy the wiring harness)
- Dremel or a chisel
- Hot glue or silicone
- Small phillips screwdriver
- PC running Windows XP
Remove these ads by
Signing UpStep 1Program your U-HID Nano
I hooked the wires up to a temporary switch at this point for programming the thing. You could go ahead and hook it up to the Easy Button. Just scan down a little to see which contacts to use.
You program the U-HID Nano with U-Config, a software package available from the manufacturer. It's a pretty easy process, and the Technical Manual was easy to read.
I'm not going to go into the details here except to note that a driver install and firmware update were required to get it working on my machine. Both of those processes are clearly documented on their site. I set it up so that when pin 10 goes to ground, it will send the macro "L Alt, F8". It seems to send the scancodes fast enough that my machine counts it as a combination keypress.
comments
Add Comment
powerfulmojo (author)
says:
Add Comment
