3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Easy Button
Step 2Take the Easy Button Apart
Turn the button over, and you'll see four black pads on the bottom. Pull them off to expose the screws. Be sure to save the pads so you can stick them back on. Go ahead and take the batteries out while you're there.
Desolder Everything
Remove all 4 screws to release the silver ring and red button from the assembly. You'll be left with just the guts of the machine. Inside, you should see a white button. That is the heart of the Easy Button and the only part of the original electronics we're actually going to make use of.
All of these things have to go, so desolder and discard them:
  • The black capacitor
  • The resistor closest to the button
  • The red speaker wires
  • The black & white power wires
If you don't know what those things are, don't sweat it. Take a look tommybear's photos on flickr. He's better at this than I am.
Remove the 2 screws, and take the PCB off of the assembly. Set the metal spring aside. We want to keep that because it pops the button back up after it's pushed. Besides, it gives a satisfying CLICK that I like.
Remove the 4 screws that hold the little mezzanine level on. You may have to pry it up just a bit if the hot glue below is sticking it down. Take the metal slugs out and discard them. They're just stuck in there with a little hot glue and you can pick them out without ruining anything. I guess you could leave them if you have the room & like the heft. Remove the speaker too.
Use your dremel or a chisel to take out any little plastic bits that are in your way. Just remember that you have to leave the 4 posts that hold the mezzanine level up.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:powerfulmojo
Name's Andy Allen.
