Step 4Let the Wire Out
It should only go back together one way: with the battery compartment farthest away from you, the "easy" label should be right-side up and the Staples logo on the ring will be directly toward you. Replace all 4 screws in the bottom of the case and use a little hot glue to stick the rubber pads back on. You're done with the hardware: you've built an Easy Button that actually does something.
Add Comment
