3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Electronics Organizer - Sew Useful
Step 8Sew Middle and Side Lines
  • last photo ←
Before you can sew all three pockets onto your background fabric, you will need to baste them on.
Using a needle and thread tack down all letter A points on the vinyl to the corresponding point on the fabric. You will notice that the vinyl is one half inch away from the edge. This is to give you a little wiggle room when you attach it to the board later.
I am using a bright contrasting thread for demonstration purposes.
The largest pocket on the bottom and the smallest is on top.
Pin quarter inch ribbon or seam binding from top to bottom on the lines. If your machine has a small or non-stick presser foot, the ribbon should be enough to prevent sticking. Otherwise, use paper here.
Sew through outside lines first and then through ribbon covered middle lines.
Remove any visible basting thread.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Aly
