Make a game pad with an accelerometer inside!
This project tutorial will show you how you can convert a console game pad into a USB keyboard mouse for playing games on your PC. The USB game pad can be used with nearly any software, such as a MAME emulator, game, simulation software, or for custom user interfaces.
We'll start by turning the buttons of the game pad into keyboard buttons, so that pressing 'up' is converted into the 'U' key, for example. The firmware is easily adaptable, so you can adjust it for whatever software it will be used with.
Then we'll make the project more interesting by adding an accelerometer. This will allow the game pad to be used as a mouse by tilting it!
Credits
This tutorial including the original code and Portal video is by Devlin Thyne! Rock!
Remove these ads by
Signing UpStep 1What You'll Need...
You'll need the following in order to build the project:
- Game pad - We'll be using an SNES controller
- Teensy - This is a very small microcontroller board that can act as a keyboard/mouse
- Triple-axis accellerometer - We'll be using the nice ADXL335 on a breakout board. You can skip this if you're not planning to add in the mouse capability
- USB cable with mini-b connector - to attach to the Teensy for plugging into a computer!
- Ribbon cable - for all the soldering connections. Rainbow cable is the easiest to work with as its color coded
If you want to build the entire project, we have a project pack in the shop with all the parts listed above!
You'll also need some basic hand tools such as screwdrivers, wire strippers, soldering iron, solder, diagonal cutters, vise or third hand tool, etc.
All the code is on GitHub, including some extra sketches we've written so be sure to look there!
The big downside is that it would likely involve a care mod to fit the keyboard PCB in with the rest, or I suppose you could run all of the switch leads in a thicker cable to the keybaord PCB in a separate housing.
Whether or not this is worthwhile is probably a factor of your budget. It'll add some hassle but save $20 for the Teensy.
I've done the same thing some time ago with a "full" DIY version :
You have 2 possibilities :
1 - raphnet.net/electronique/snes_nes_usb/index_en.php
he use an atmega 8 with a xtal for the pad-usb conversion. It's a nice idea, but the overall size of the project (if you do it without a PCB) is a tad big to fit inside the pad.
2 - translate.google.ca/translate
He use a small Attiny 45 with internal osc for the pad-usb conversion. I've used this method for my own pad. It fit quite easily in a SNES gamepad. I didn't have any Attiny45 on hand, but I had some Attiny25... I've managed to make the code smaller and include the auto usb calibration. It was quite a tight fit in the 2k memory! I'll try to post my modified files for you to enjoy.
I might even post an instructable if I have some spare time.
http://translate.google.ca/translate?hl=fr&langpair=de|en&u=http://hobbyelektronik.org/w/index.php/SNES-Joypad
