Introduction: USB HANDLIGHT
A simple usb hand light which is operated very less than 5 volts
Step 1: Step 1: Materials Required
A old usb cable
A 100 ohm resistor
A led
Step 2: Step 2: Construction and Working
A usb has 4 pin out
1 +5v(supply)
2 data in
3 data out
4 ground (0v)
neglect pin 2 and 3
Step 3: SOLdering
solder a 100 ohm resistor to a +5 v pin (supply pin)
connect a small wire to ground pin
neglect data pins
solder a positive side of led to other side 100 ohm resistor
negative side of led to ground
A simple usb hand light is done
