iImage Information
I have a Dynex add-on four port USB hub. After about a month, the ports stopped working one by one. This is a common complaint among those who have reviewed this hub at Amazon.com. But, all is not lost.
Step 1What happens
iImage Information
You insert your thumb drive and nothing happens. The thumb drive you see in the hub here has a blue LED inside its end that is supposed to flash when plugged into the hub. Sometimes it does not. No box appears on my computer screen asking me if I want to play or view files on the drive.
However, I am also using a metal usb hub:
http://ecx.images-amazon.com/images/I/31rlEB1kIsL._SL500_AA300_.jpg
There has to be an easy way to ground these things!
Thanks for posting though. Huge help!
If you have a metal case on your hub, you can attach a light flexible bare wire to the metal and connect it to the metal frame of your computer tower. Touch the metal hub case and then add or remove your device.
Thanks for your comment. It is good to know someone was able to use this.
1. Unplugged power-supply
2. Unplugged usb-to-computer cable
3. Unplugged all usb devices from all ports
4. Plugged in power-supply
5. Plugged in usb-to-computer cable
6. Plugged in all usb devices as they were.
Bingo! So now I have to go clear out my shopping cart at newegg. :) THANKS!
