3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Hub inside Altiods Tin
Step 3Installing cardboard and hub
After you have cut your holes glue in a piece of card board cut to the size of the Altoid tin. I used hot glue but anything will work. The reason you glue in the card board because the circuits on the bottom of the hub overload when it touches the tin. Also if you haven't taken your hub out of the case yet do that now but be careful because when I took off my cover I snapped off a resistor and had to solder it back on. Once you have glued in the card board you can glue in the hub. Make sure the ports are sticking out a little so plugs can stick into them. One way to test this before you glue it is stick a plug into all of them. Also if you want to have the hub plugged in while the tin is closed then drill a hole in the side for the cord.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Superninjacamper941
