USB IR Remote Control for Your Desktop / Laptop
Published
Introduction: USB IR Remote Control for Your Desktop / Laptop
About: embedded system enthusiast ...
 USB IR Remote Control For your  Desktop / Laptop computer
 control your computer media player software  using  IR remote control.
  •  customizable and easy  program design
  •  minimal components
  •  multiple remote decoding support
  •  USB operation [ No need for serial port ]  suitable  for laptop.
Step 1: Arduino Leonardo
Overview
The Arduino Leonardo is a microcontroller board based on the ATmega32u4 (datasheet). It has 20 digital input/output pins (of which 7 can be used as PWM outputs and 12 as analog inputs), a 16 MHz
crystal oscillator, a micro USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. The Leonardo differs from all preceding boards in that the ATmega32u4 has built-in USB communication, eliminating the need for a secondary processor. This allows the Leonardo to appear to a connected computer as a mouse and keyboard, in addition to a virtual (CDC) serial / COM port.
Summary
MicrocontrollerATmega32u4 Operating Voltage5V Input Voltage (recommended)7-12V Input Voltage (limits)6-20V Digital I/O Pins20 PWM Channels7 Analog Input Channels12 DC Current per I/O Pin40 mA DC Current for 3.3V Pin50 mA Flash Memory32 KB (ATmega32u4) of which 4 KB used by bootloader SRAM2.5 KB (ATmega32u4) EEPROM1 KB (ATmega32u4) Clock Speed16 MHz
http://arduino.cc/en/Guide/ArduinoLeonardoMicro?fr...
Download the Arduino Software
http://arduino.cc/en/main/software#toc2
usb driver installation steps
http://arduino.cc/en/Guide/ArduinoLeonardoMicro?from=Guide.ArduinoLeonardo
Step 2: Arduino Remote Control Library
arduino tsop receiver library
Infrared remote library for Arduino: send and receive infrared signals with multiple protocols
http://arduino.cc/en/Tutorial/RobotRemoteControl
Download: Arduino IRremote Library
Step 3: VLC Hotkeys Table
  • Fullscreen key-toggle-fullscreen f
  • Leave fullscreen key-leave-fullscreen Esc
  • Play/Pause key-play-pause Space
  • Pause only key-pause [
  • Play only key-play ]
  • Faster key-faster +
  • Slower key-slower -
  • Normal rate key-rate-normal =
  • Faster (fine) key-rate-faster-fine Unset
  • Slower (fine) key-rate-slower-fine Unset
  • Next key-next n
  • Previous key-prev p
  • Stop key-stop s
  • Position key-position t
  • Very short backwards jump key-jump-extrashort Shift-Left
  • Very short forward jump key-jump+extrashort Shift-Right
  • Short backwards jump key-jump-short Alt-Left
  • Short forward jump key-jump+short Alt-Right
  • Medium backwards jump key-jump-medium Ctrl-LeftM
  • Medium forward jump key-jump+medium Ctrl-Right
  • Long backwards jump key-jump-long Alt-Ctrl-Left
  • Long forward jump key-jump+long Alt-Ctrl-Right
  • Next frame key-frame-next e
  • Activate key-nav-activate Enter
  • Navigate up key-nav-up Up
  • Navigate down key-nav-down Down
  • Navigate left key-nav-left Left
  • Navigate right key-nav-right Right
  • Go to the DVD menu key-disc-menu Shift-m
  • Select previous DVD title key-title-prev Shift-o
  • Select next DVD title key-title-next Shift-b
  • Select prev DVD chapter key-chapter-prev Shift-p
  • Select next DVD chapter key-chapter-next Shift-n
  • Quit key-quit Ctrl-q
  • Volume up key-vol-up Ctrl-Up
  • Volume down key-vol-down Ctrl-Down
  • Mute key-vol-mute m
  • Subtitle delay up key-subdelay-up h
  • Subtitle delay down key-subdelay-down g
  • Audio delay up key-audiodelay-up k
  • Audio delay down key-audiodelay-down j
  • Cycle audio track key-audio-track b
  • Cycle through audio devices key-audiodevice-cycle Shift-a
  • Cycle subtitle track key-subtitle-track v
  • Cycle source aspect ratio key-aspect-ratio a
  • Cycle video crop key-crop c
  • Toggle autoscaling key-toggle-autoscale o
  • Increase scale factor key-incr-scalefactor Alt-o
  • Decrease scale factor key-decr-scalefactor Alt-Shift-o
  • Cycle deinterlace modes key-deinterlace d
  • Show interface key-intf-show i
  • Hide interface key-intf-hide Shift-i
  • Take video snapshot key-snapshot Shift-s
  • Go back in browsing history key-history-back Shift-g
  • Go forward in browsing history key-history-forward Shift-h
  • Record key-record Shift-r
  • Dump key-dump Shift-d
  • Zoom key-zoom z
  • Un-Zoom key-unzoom Shift-z
  • Toggle wallpaper mode key-wallpaper w
  • Display OSD menu on top key-menu-on Alt-Shift-m
  • Do not display OSD menu key-menu-off Alt-Ctrl-m
  • Highlight widget on the right key-menu-right Alt-Shift-Right
  • Highlight widget on the left key-menu-left Alt-Shift-Left
  • Highlight widget on top key-menu-up Alt-Shift-Up
  • Highlight widget below key-menu-down Alt-Shift-Down
  • Select current widget key-menu-select Alt-Shift-Enter
  • Crop one pixel from the top key-crop-top Alt-r
  • Uncrop one pixel from the top key-uncrop-top Alt-Shift-r
  • Crop one pixel from the left key-crop-left Alt-d
  • Uncrop one pixel from the left key-uncrop-left Alt-Shift-d
  • Crop one pixel from the bottom key-crop-bottom Alt-c
  • Uncrop one pixel from the bottom key-uncrop-bottom Alt-Shift-c
  • Crop one pixel from the right key-crop-right Alt-f
  • Uncrop one pixel from the right key-uncrop-right Alt-Shift-f
  • Random key-random r
  • Normal/Repeat/Loop key-loop l
  • 1:4 Quarter key-zoom-quarter Ctrl-1
  • 1:2 Half key-zoom-half Ctrl-2
  • 1:1 Original key-zoom-original Ctrl-3
  • 2:1 Double key-zoom-double Ctrl-4
  • Very short jump length (integer) extrashort-jump-size 3
  • Set playlist bookmark 1 key-set-bookmark1 Ctrl-F1
  • Set playlist bookmark 2 key-set-bookmark2 Ctrl-F2
  • Set playlist bookmark 3 key-set-bookmark3 Ctrl-F3
  • Set playlist bookmark 4 key-set-bookmark4 Ctrl-F4
  • Set playlist bookmark 5 key-set-bookmark5 Ctrl-F5
  • Set playlist bookmark 6 key-set-bookmark6 Ctrl-F6
  • Set playlist bookmark 7 key-set-bookmark7 Ctrl-F7
  • Set playlist bookmark 8 key-set-bookmark8 Ctrl-F8
  • Set playlist bookmark 9 key-set-bookmark9 Ctrl-F9
  • Set playlist bookmark 10 key-set-bookmark10 Ctrl-F10
  • Play playlist bookmark 1 key-play-bookmark1 F1
  • Play playlist bookmark 2 key-play-bookmark2 F2
  • Play playlist bookmark 3 key-play-bookmark3 F3
  • Play playlist bookmark 4 key-play-bookmark4 F4
  • Play playlist bookmark 5 key-play-bookmark5 F5
  • Play playlist bookmark 6 key-play-bookmark6 F6
  • Play playlist bookmark 7 key-play-bookmark7 F7
  • Play playlist bookmark 8 key-play-bookmark8 F8
  • Play playlist bookmark 9 key-play-bookmark9 F9
  • Play playlist bookmark 10 key-play-bookmark10 F10
Step 4: How to Find the Remote Code
1, load this program file  in to your arduino leonardo board
2, follow the  wiring diagram
3, open arduino IDE -> serial monitor
4, test your remote
Step 5: Arduino Program - Add Remote Codes
/////////////////////////////////     USER IR REMOTE CODE  [SONY LCD TV REMOTE ]    ///////////////////////
#define PLAY                  0X2CE9
#define PAUSE                0X4CE9
//#define PLAY_PAUSE   0X0A70
#define VLC_ON             0X0A70
#define NEXT                  0X5EE9
#define PRVS                 0X1EE9
#define STOP                  0X0CE9
#define MUTE                  0X0290
#define VOLUME_UP      0X0490
#define VOLUME_DN      0X0C90
#define JFWD                  0X1CE9
#define JBWD                 0X6CE9
#define EXIT                    0X0A90
Step 6: Arduino Program - Add Hot Keys
Keyboard.write();
  single key press
eg: Keyboard.write('s');              //key s for stop in vlc player
Keyboard.press();
 modifier keys,cursor movement key
  eg:    Keyboard.press(KEY_RIGHT_CTRL);
, Keyboard.press(KEY_RIGHT_SHIFT );   Keyboard.press(KEY_LEFT_ARROW);
Keyboard.releaseAll();   release the modifier keys function
///////////////////////////  MEDIA PLAYER HOT KEYS   /////////////////////////////////
#define PLAY_FUN                      Keyboard.write(']');
#define PAUSE_FUN                    Keyboard.write('[');
//#define PLAY_PAUSE_FUN       Keyboard.write(' ');
#define VLC_ON_FUN                 Keyboard.press(KEY_RIGHT_CTRL);   Keyboard.press(KEY_RIGHT_ALT);
                                                     Keyboard.write('v'); delay(100);  Keyboard.releaseAll();    //VLC shortcut  [ alt+ctrl+v ]
#define NEXT_FUN                      Keyboard.write('n');
#define PRVS_FUN                     Keyboard.write('p');
#define STOP_FUN                     Keyboard.write('s');
#define MUTE_FUN                     Keyboard.write('m');
#define VOLUME_UP_FUN          Keyboard.press(KEY_RIGHT_CTRL);   Keyboard.press(KEY_UP_ARROW);
#define VOLUME_DN_FUN         Keyboard.press(KEY_RIGHT_CTRL);   Keyboard.press(KEY_DOWN_ARROW);
#define JBWD_FUN                    Keyboard.press(KEY_RIGHT_SHIFT ); Keyboard.press(KEY_LEFT_ARROW);
#define JFWD_FUN                      Keyboard.press(KEY_RIGHT_SHIFT ); Keyboard.press(KEY_RIGHT_ARROW);
#define EXIT_FUN                       Keyboard.press(KEY_RIGHT_CTRL);   Keyboard.write('q');
Step 7: Arduino Program - Add a New Function
#define   <KEY name>       <remote code >
eg:  #define   NEW_HOTKEY       0x70
#define   <hot_macro>            <single key /key combination>
eg: #define  STOP_FUN             Keyboard.write('s');   //write s for stop
add if else ladder
else if (results.value==<KEY name>)        {hot_macro }
eg: else if (results.value==EXIT)        {EXIT_FUN;      }
compile and upload your code.
Step 8: Arduino Program
install IR library
step 1: download
https://codeload.github.com/shirriff/Arduino-IRremote/zip/master  library
step 2: copy to arduino installed folder
                                                               eg:    [ C:\Program Files\Arduino\libraries ]
step 3: restart  arduino IDE
Step 9: Arduino Keyboard and Mouse Library Functions
Step 10: Wiring Diagram
Step 11: Video
Step 12: Reference
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
