Step 4: Finishing and installing the Globe
1.Trim all but 1/2 inch of the wic guide off
2. We need to remove all the guts but the turn key out the wic adjustment cap.(Tin snips work great but so will a nice dremel.)
3. Now we need to put the screw cap back on the globe with a little RTV.
4.I did not replace the retaining clip for the globe base as it will be easy to remove the globe should you have to if the clip is not installed. With some RTV fill the area where we trimmed off all but 1/2 if the wic guide, set the globe in place make sure it is level or again it will look uncool. let dry an hr or so before touching.
5. connect your wires insulate them and stuff them up over the globe out of sight.
( as you can see I did not make sure my globe was level and is now crooked and I am using wire to make it look correct. learn from my mistake)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
