Introduction: USB LED Light
In this instructable, I will show you how to make a USB light. plug into the USB and watch it glow...
For hours...
Sorry, the pictures are bad.
Everything you need is probably sitting in a dark corner in your garage. It will give you a reason to get out that old rusty soldering iron.
Any of this stuff can be pulled off other electronics so you don't have to buy anything.
and waste all that packaging
to just go to a landfill
and fill up
For hours...
and fill up
Step 1: Get Your Things
The Tools:
Wire Cutters
Needle-nose Pliers
Glue (super glue is not good, It gets soaked up)
Clamps
Sandpaper
Belt Sander
Solder
Soldering Iron
Flux
The Supplies:
LED (Better if its high power, 3-3.5V)
Metal edge of a wooden ruler (or other small, flat conductor that bends)
Resistor (Also, depends on the type of LED) I used a 220 ohm, but it depends.
Masonite (or something that is similar) I used that hole board (because it's what I had)
You could recycle the LED from a flashlight or other thing that has not been working. All you need to do is to open it up and yank it out.
Same with the resistor.
Wire Cutters
Needle-nose Pliers
Clamps
Sandpaper
Belt Sander
Solder
Soldering Iron
Flux
The Supplies:
Step 2: Cut It Out!
Cut the board into smallish pieces. (see pictures)
Step 3: Sanding
Sand the edge of the board so that it will fit into the USB. Don't sand the top.
Sand the bottom to remove rough edges
Hold it up to the edge of the sander to get a stamp that will fit into the USB snugly. (pic 2)
Sand it a little more after that so it will fit when the metal edge is put on.
Sand down the sharp edge so that it is smooth all the way over the top.
Step 4: Glue
Pull the strip out of the ruler.
Cut it so that it fits on top of the sanded wood stuff.
Bend It so that it is the same curve as the woody stuff.
Do it twice
Smother the wood stuff in glue and clamp on the metal strips.
Make sure that they only hit the outer 2 metal things inside the drive.
There are 4 strips inside a USB drive. The 2 outer ones are the ones that give off an electric current of 5 volts. The right is positive and the left is negative.
When dry, sand off the top of the strips. It sticks to the solder better.
Do it twice
Step 5: Solder!
Solder the resistor onto the right-most metal strip.
Solder the + side of the LED to the left strip.
Solder the - side to the resistor.
Bent it however you like so that it looks good. (That's what counts!)
Step 6: Plug It In!
Plug it in and watch it glow!
