SCHEMATIC
This instructable has been removed by the author.
93 comments
1-50 of 93next »
Feb 25, 2009. 10:06 PMaj218 says:
I made a 16x80 display with 8051 but i m as more characters scroll the display is getting flickering, why??
Feb 25, 2009. 12:26 PMemil_ivanov says:
could I get the both sides separately. please ...Thanks !
Feb 22, 2009. 2:46 AMJoell says:
hey, this may have already come up but i dint have time to go through all the comments but could u offer a coupla tips on scaling a project like this? Like if i wanted to make a larger sign or something...
Feb 12, 2009. 1:44 PMfelipe22 says:
I too have the ability to use pcb123 software could you share the pcb file ? I would also be happy to convert it and post it.
Nov 27, 2008. 9:47 AMise says:
in the schematic isn't the led driver, is the current from PIC enough for LEDs and safety for PIC?
Nov 24, 2008. 7:27 PMshimadax says:
im new to this and i was wondering what kinda power supply did you use for this project, thanks
Nov 24, 2008. 4:54 AMjepoy says:
what a wonderful project... hey guyz... i'm jef from the philippines... we're making a project that displays using 80 dot matrices... in our design, we need at least 36 i/o pins from the microcontroller... i found pic16f887microcontroller by microchip, but its programmer is too expensive... could anyone help me find a circuit diagram for our programmer... your help is greatly appreciated guyz... thanks a lot...
Nov 19, 2008. 3:58 PMbronx68 says:
It looks like you setup the column data then activate the a row, setup the column data and then activate the next row, etc.. Have you tried setting up row data and then clock columns? See any advantages with either technique?
Sep 9, 2008. 4:47 PMmunchman says:
This is awesome. What was the total cost of this project?
Sep 9, 2008. 4:58 PMmunchman says:
Does anyone know where I could get the parts in Australia?
Nov 8, 2008. 1:45 PMe4g1e says:
Jaycar.
Nov 6, 2008. 12:46 PMmooboo says:
Hi great Project! just wondering, do you have individual pcb layouts for each side? if you do would be much appreciated. thanks.
Oct 14, 2008. 7:46 PMoreoshake says:
this project makes no sence how do you hook up the 2 circuts ??????? you have 1 that has the mclr and shift registars that schem has no parts listed for the small components i realy need help
Sep 28, 2008. 5:48 PMjmaurin says:
Thank for this project!! Can you share the source? Tks!
May 23, 2007. 5:17 PMjaypp says:
can this be made using a PIC1684a? i am a complete beginner and these are the only PICs i have avalable to me at school.
May 24, 2007. 8:22 AMjaypp says:
ok, so the PIC1684a cant be usb programmed? what is the 2550, soz i dont know a lot about this. I was also wondering if you knew if it was possible to use a winamp plugin to power the sequence the the leds flash in?
May 25, 2007. 6:18 AMjaypp says:
thanks for those links they are very helpful, i was actually going to try and make the leds powered by the easy chords plugin for winamp which shows guitar chords and tabs. i am trying to make a guitar which has leds under the fretboard to show where you need to put your fingers for a chord, so you can play along in winamp. i don't know how possibly it is have you got any suggestions? thanx
Aug 2, 2008. 9:31 AMtwoolie says:
Another question, where do you plan to put these LEDs? the fretboard of a guitar is highly tensioned and caries both a large moment and compressive load. therefore it would certainly not be in your best interests to start drilling holes for LEDs and putting surface mount leds between the frets would obstruct finger placement. your best bet would be to get in touch with someone who builds guitars for a living and get them to build your circuit right into it.
May 25, 2007. 11:58 AMjaypp says:
the amount of leds depends on the amount of chords i will want but the maximum is 6 (strings) x 22 (frets) = 132, however i will probably use much less than this. I am not sure which PIC to use, the only PICs we have at school are the PIC1684a with a PIC logicgator pic programmer. Is it possible to use this programmer with other PICs?
Aug 2, 2008. 3:00 AMtwoolie says:
Here is a question. how did you overcome the dimming problem, i.e. if you have a sign 10x as large and only use the same row driver for all, the LEDs will have a 10th the brightness.
Jul 22, 2008. 1:03 PMMoonglass says:
I need help with the communication to the pic, or better I need the software to communicate with the usb sign please !!! I have build it and can´t do anything with it :-(
Jul 21, 2008. 12:12 AMdasariphani says:
if use 89s8252 will cost more or 18f4550
Jul 18, 2008. 4:11 AMameriq says:
wat if i want to use 18f4550
Jul 6, 2008. 7:07 PMajfer says:
I was wondering did you use an LED driver in the schematic at the end of your project?
Jul 4, 2008. 10:52 AMMoonglass says:
has anybody the software in this video to control the usb led sign? please send me a mail: moonglass@web.de yours jens
Jun 17, 2008. 6:52 PMqwixel says:
Any chance of a set of gerber and drill files?
Jun 20, 2008. 2:29 PMburzvingion says:
not with pcb123... they only let you use their proprietary format.
Jun 21, 2008. 7:51 PMqwixel says:
I have access to other software that can generate gerbers. I could get pcb123 and use it as a reference to rebuild the files for you in gerber & excellon if it interests you.
Apr 16, 2008. 6:52 AMsamurai says:
Hi , I recently tried out 8x8 led matrix display. I used PIC16f877. to drive columns i used TPIC6B595. (although the PIC has plenty of pins i'm thinking of flexibly expanding the number of columns later. that's why i used the shift reg.) The problem is when column scanning frequency is about 80 Hz or above, I get shadows in the display. Think this is because the shitft reg. drain output fall time is not fast. i.e. when column2 is being lit, column 1 also get a shadow of this column 2. (i.e. both column 1 & column 2 selected) but i think TPIC6b595 had been used by many without problem. what's the max column scanning freq. you have gone? pls help.
Jun 20, 2008. 2:26 PMburzvingion says:
millingabout is correct. You're probably forgetting to blank the column drivers while you update the row data. I'm currently working on a similar project that uses the TPIC6595 (no B), which is the higher power but slower cousin of the TPIC6B595. I've tested them at several kHz, and they performed admirably, so it's not the chips themselves.
Jun 6, 2008. 8:45 AMmillingabout says:
Most chips work fine up to the M Hz range, but to your point each chip is different. Try deselecting all rows prior to changing the column.
Jun 19, 2008. 7:28 PMchrisayad says:
thats funny LOL i have like 457347062342 led modules and im still trying to get rid of/use them help me out and buy them from me hahah!! dont have time to build!!
Jun 19, 2008. 5:22 PMoktane says:
Here is a very old circuit, it may be useful to those building large arrays. It can handle the current of at least 672 T1 LED's! It does not include the micro controller section, just the matrix and driver details. It was reverse engineered from a very large sign. It was once driven by an 8085. :D
Nice Instructable!
Original PNG
Jun 15, 2008. 12:47 AMkensterdotnet says:
I've always wanted to make something like this, but I have zero experience with any of it. I don't know where to start and pick up the information on schematics and stuff. Do you guys have any websites where I can read this stuff?
Jun 13, 2008. 12:23 AMDerin says:
May 15, 2008. 4:58 AMiyas says:
Full diagram circuit plzzzz...
Jan 2, 2008. 9:55 AMpcwires says:
Cool display,I started working on a similar 1, hand made led matrix like your earlier ones.Looking into rf remote programmer so no need for PC's to re program.
Heres a clip on you tube.
http://uk.youtube.com/watch?v=G7noAIb5gJ0
Apr 22, 2008. 11:53 AMIvan1983 says:
hi pcwires yes I would like to build the scrolling sign.my e-mail is "idimkin@abv.bg" can you send me everything that i need to biuld this projekt.thanking you in anticipation.
Mar 9, 2008. 4:10 PMbronx68 says:
yes I would like to build the scrolling sign. How can I get details?
Mar 9, 2008. 6:04 PMpcwires says:
Hi bronx68, Just got a message from the instructables robot,Do you wish to build the usb display if so then thats not mine. My display is the one with the link to you tube.Email to confirm Paul@paulcollett.fsnet.co.uk. Thanks, Pcwires.
Mar 9, 2008. 6:33 PMbronx68 says:
I am looking to build a scrolling led display. Is yours a scrolling led display? If so are schematics, assembly code, kits available?
Mar 10, 2008. 12:29 PMpcwires says:
Send me your email adr. My sign is scrolling have a look at the video on you tube.Click on the link in my previous comment.
Mar 11, 2008. 6:18 AMbronx68 says:
my email is ray.phillips@articulux.com
Apr 22, 2008. 5:40 AMIvan1983 says:
how conecting the LEDs with PIC?
Apr 21, 2008. 8:59 AMsayem ahmed says:
I am doing this project. I am now working on hardware section. It is pretty easy. I am thinking about how I can add my massage in my sign. Is it in 256 eeprom build in 18f2550. One another problem is how can I cascade 10 74hc595. Is somebody complete this project. Please reply.
Apr 15, 2008. 6:44 AMsayem ahmed says:
I would like to build the scrolling sign. How can I get details?I lke the USB LED scrolling marquee sign. I need a complete schematic of the scrolling marguee sign. Please send me the schematic as soon possible. Anybody help me. My mailing address is sayem72936@yahoo.com
1-50 of 93next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:led555
