3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Midi Device from old Gamepad
Step 9Solder resistor to the LEDs (optional)
Solder a 220-Ohm to the long (positive) end of each LED. This will insure your LEDs do not burn out. Extend the other peg with a wire to connect to a ground.
2 comments
Nov 14, 2009. 9:08 AMiGianlucaConidi says:
I would like if i used differents led to understand that resistance should i use?
could use witouth resistance?
Jun 30, 2009. 6:37 AMamplex says:
different leds might need different size resistors. in practice ive found that most schematics use 4.7k resistors to protect leds but these make them too dim. but the leds i buy in general need only 270ohm or so to be brightly lit. experiment because some leds have different voltage capacities/current usage etc. this is an awesome project idea btw!!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:cheft
