USB Mini Drill
12,265
192
16
Posted
Introduction: USB Mini Drill
This USB powered drill is perfect for wood, PCB boards, bakelite, cardboards and many more.
Very simple to make, a perfect utility tool for DIY hobbyists.
This tool besides a power bank can also be used by plugging in any 5v USB mobile charger.
Step 1: ​Things You Need
Things you need:
Cable, USB plug, Mini switch, Mini motor, Electrical connector, Small drill
Step 2: Connect the Switch
Glue the switch on the + side of the engine.
Step 3: Connect Cable to Motor
Solder the red cable (+) to the switch and the white (-) to the engine , remember to solder the switch.
Step 4: Connect Cable to USB
Solder the red cable (+) to the + USB and the white (-) to the – USB.
Finish it off with tape and shrink tubing,
don't tape the switch!
Step 5: Connect the Drill
Cut the ends of the electrical connector.
Glue the drill and motor together in the connector.
Step 6: Ready!! Let's Take It to the Test!
See the end of the video for test!!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
16 Comments
where do you get the motor?
Awesome the way you used that connector to couple drill bit and motor shaft, very useful
a clockers must -- if your CPU gives thermal -- you just drill more holes to the PC case (shot up me stupid cat, muhahaa)
If you want to reduce chance of damaging your USB port, try the next configuration.
I mean add a Diode like people said on previous comments xD
I don't see any EMF or spike suppression circuitry, I'm not sure I would use the USB rail as a power source for this, motors throw out a heck of a back voltage.
BeachsideHank thanks for the reply!
isnt it allready on the motor?
I hope someone else can verify, but it looks like a simple disk capacitor to me.
i'm gonna check this next week. i'll let you know what it is!
