3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Mini Fan
USB Mini Fan
This Mini Fan as been made out of a broken toy car's DC Motor. It works very well and is good to use it when you are working on your PC. The speed of the Motor is good and it does not heat up because of the 470pF capacitor used.
The tilt of the Fan blades determines the amount of air flow.
The Fan Blades is tilted at an angle of 45 degrees.
Step 1Parts of the Fan
Parts of the Fan
To make the stand of the Fan I have used the following items.
A piece of PVC cut out of a face powder container to make the fan blade.
A small PVC Box with weight inside to make the Base of the Stand.
A metal door handle is used to increase the height of the stand.
Attached to it is a wooden batten with Mortise Tenon joint to facilitate the movement of UP of Down.
Two pairs of Nut and bolt.
A thin PVC sheet to hold the Motor in place.
Two thumb nails to keep the Electrical wire in place.
Four tin screws are used fix the door handle and the wooden batten.
14 comments
Apr 17, 2012. 10:03 AMnodoubtman says:
why do you place a capacitor on the motor??
Feb 22, 2012. 8:46 AMabhinkul says:
Hi! Where can I get the thin PVC sheet for making the fan blades?
Nov 26, 2011. 7:58 PMZappingLover1337 says:
im new so pleez help me thanks is not enough if u do help so ultra thanks!!!!!
Nov 11, 2011. 10:43 AMRobot Lover says:
I would like to suggest that you put a diode between the motor leads like you did the capacitor. This will protect your USB port from blowing up from a sudden surge of power when the fan is stalled or turned off.
Oct 30, 2011. 5:27 AMrimar2000 says:
Very good workm Dipankar. I suggest you try my easy propeller, it is more efficient due to less turbulence.
Oct 31, 2011. 11:29 AMrimar2000 says:
That propeller is fully scalable, you can do it using a little collyrium plastic bottle, in example. Because it have little turbulence, it needs less power to give same output.
Oct 30, 2011. 8:16 AMlukeD says:
why the capacitor??
*4
Oct 30, 2011. 9:15 AMRobot Lover says:
It eliminates AC ripples. It helps it to run the motor properly and efficiently.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
115
Author:Dipankar(http://authorschoise.blogspot.)
Now I am a retired person, who enjoys life and making small things to pass the time keep myself busy.
