3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
U.S.B. Mini Fan
U.S.B. Mini Fan
This is my my first instructable so please be nice, also I have already built it so I had to make the pictures on word.
For this project you will need
- Any old U.S.B. cord
-An old computer fan
-Wire cutters/strippers
-multimetre
-Computer to try it out on
Step 1Sort out the cable
Sort out the cable
Get out your U.S.B. cord and find the end with the plug that would go into to device. (no the computer)
5 comments
Aug 29, 2011. 2:24 AMlemonie says:
If you're going to do things like this, you tell us which coloured wires you found to be the + and -. Why have people waste their time finding out for themselves when you've already learned it?
-What is "Fail tape" (step 5 image note)?
L
Aug 26, 2011. 2:51 PMkenkaniff says:
I'm sure this has been brought up a million times, but is it really safe to run a 12V fan off of a 5V port? I can't imagine the fan runs very fast, and wouldn't it possibly burn out the port/whole computer?
Aug 26, 2011. 4:29 PMironsmiter says:
Safe? yes.
Burn out USB? not unless something goes horribly horribly wrong.
You're feeding the fan 5 volt, at 100mA max.
If it will start on that voltage, it should run no problem.
MOST 12 volt fans I have worked with need closer to 7 volt to start, and will continue to running on as little as 3 volt, once moving.
SMaller case fans, cpu cooler fans, laptop fans, etc... they often will start on lower voltages.
Running on 5V WILL cause the fan to run much slower, but if all you want is a gentle breeze, then it might be fine.
http://www.techpowerup.com/articles/other/137
While the article I linked deals with molex powered fans... the principal is the same. The major difference is, a molex connector can usually source a LOT more than 100mA available to a standard usb port(note: 100mA is WITHOUT the usb handshake/shorted wire trick needed to bring the 500mA power for use)
Aug 26, 2011. 5:20 PMkenkaniff says:
Alright your information looks to be all in order...
That's actually the first time I've gotten a detailed answer. Thanks!
Aug 26, 2011. 2:49 PMzack247 says:
its a good instructable, but--
real pictures are always better than pictures drawn in mspaint.
some people prefer visual references to what theyre doing rather than digital references.
not speading hate or anything, but its a suggestion for your future instructables.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:super tubes
I am a Canadian boy that likes to make, invent, and tape things. my current project is a chocolate 3D printer. :-)
