3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB-Powered Apple
Step 8Testing testing... 1 2 3...
Flip the apple right side up. Make sure the apple is not coming into contact with any strong electrical fields such as you or a cell phone.
Plug it in.
Nothing should happen.
Now put your hand around it.
It should vibrate.
however...
If you plug it in and it starts to vibrate and never stops then you can have one of many problems:
1. Your wiring is wrong.
2. Somewhere on the circuit wires are being crossed.
3. Ground wires are making contact with your electrode.
4. You have not used shielded cable for your electrode.
5. You have wired your shielded cable wrong.
If you plug it and nothing happens and then when you touch it nothing still happens:
3. Your chip or transistor may be dead.
4. Your USB cable is busted.
If you plug it in and it vibrates for 10 seconds every time you touch it then you probably are not using shielded electrode wire. The sensor is timing out and recallibrating itself every time it is triggered. Use shielded cable or fix your wiring.
1 comment
May 7, 2011. 11:41 PMsattu94 says:
You know a cross-sectional Image(drawing) of where everything should ideally be(inside the apple), will really help the beginners like me. Nice Instructable though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2357
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
