Quite what you need to complete the project:
- a fan out of a broken power supply
- a spare USB cable
- 2 CD cases, the plastic ones
- something to stick it all together : i used tape and glue
- one or more diskettes
- tools to cut through such as a pair of scissors, knives or anything you've got. I used a piece of iron heated in flames to cut the plastic casing
- a ruler and a marker to make some measurements
- a CD to test the functionality of the project as you advance
- a working computer or any device witch has USB support
- free time and some luck
So .. that's that. Let's move on to the next step as i cant tell you are eager for some trimming.
Remove these ads by
Signing UpStep 1Get the CD casing
Cut that out and stick spare plastic on the bottom of it to grow its height. Repeat the cutting procedure (in my case it was melting)
* note that to bind these plastic pieces together i used the double adhesive tape, but you can use whatever method you wish
http://www.instructables.com/id/How-to-Clean-a-CD/?ALLSTEPS
http://www.clir.org/pubs/reports/pub121/sec6.html
http://www.wikihow.com/Fix-a-Scratched-CD
Because the track is a spiral from the centre, it's susceptible to scratches that trace a circular path around the centre. So, unlike a vinyl record, you should wipe from inside to out. If a bit of accumulated glue,grit or grease is picked up on that cloth it would do a number on the CD and might make matters a whole lot worse..
