Remove these ads by
Signing UpStep 1Parts List
Electronic Parts
1. 5mm Red Blue Green Color Changing LED. You probably won't find these in your local electronics store. If you search on eBay for "5mm led rainbow rgb" you'll find them. They cost approximately $13 for 100.
2. Resistor: 82 ohms, 1/4 watt. Color bands: Gray-Red-Black.
3. USB cable with a male type A connector on one end.
4. Thin wire.
5. Heat Shrink Tubing (1/8" and 1/4" diameter) or Electrical Tape.
Light Base Parts
1. Copper pipe fitting with 1" and 1 3/4" ends.
2. #14 Cork (1" diameter on the small end and 1 1/4" diameter on the large end)
3. 1/2" Nut - (1/2" diameter center, 3/4" outer diameter)
Mystic Part
1. Clear Quartz Crystal with bottom diameter no larger than 3/4" - I got mine for $10 at a gem shop in San Francisco.
Tools
1. Soldering iron and solder.
2. Wire cutters/strippers.
3. Heat gun or similar (optional) if you're using heat shrink tubing.
4. Small metal file.
5. Scissors.
6. Drill with a 1/4" drill bit.
7. Box cutter or X-Acto Knife
TL;DR If I make this I'll try to make it turn red when baddies approach!
I did mine but i have a "problem": i used the resistor and did everyhing EXACTLY as you instructed... BUT: My led is flashing and changing colors TOO QUICKLY! Is it the resistor that controls the flow of postive current, and thus, the led is changing colors too quick or too slow depending on how much ohms the resistor has? Or maybe i purchased the wrong LED? (It looks THE VERY SAME AS YOURS, btw).
Looking Forward to your answer!
Here´s my Crystal at work (I´ve upped the vid on my blogspot, but don´t worry!):
http://infoinferno.blogspot.com/2011/06/cristal-mistico-do-rock.html
At first I was bummed because I couldn't see how it would work for this neat project (the first Instructable I've ever tried, BTW!) but after a glass of absinthe and some creative thinking I came up with an idea. It took many hours and different attempts with different materials, but ultimately I had a finished result that looks very similar to the one featured here... except that after the demo mode of my LED finishes, the crystal itself is used as a push-button to cycle through the colors. I accomplished this by setting the crystal on a nylon spacer inside the fitting with the LED glued into the center hole and flush with the surface, which actuates a momentary button switch (PC on/off switch) mounted in a base inside the fitting. The LED-spacer crystal holder stands off of the interior base via a small compression spring so that when the crystal is pushed the button closes the connection between the control and ground leads, cycling to the next setting. Finding the best combination/configuration of parts to achieve a really professional finish took WAY longer than I expected, but the end result is so cool that I may have to build another for myself, since this one is a Christmas present for my tech guru.
Thanks again for the great instructable!
superbrightleds.com - http://tiny.cc/124cw
You can choose how fast the led changes color (Slow 4sec./Fast 0.27sec.)
