Step 7Assemble the base
1. Using a 1/4" drill bit, carefully drill a hole into the center of the cork. A simple trick to make it easy to keep the cork from moving while drilling is to push it into inside of the copper pipe fitting and then hold the fitting while you drill. When the hole is drilled, gently push the cork out from the narrow end of the fitting using your fingers or the handle of a small screwdriver.
2. Check for obstructions by taking the LED cable and gently pushing it through the hole. The cable should slide smoothly through the cork. It's better for it to be snug than for it to be wildly loose. If you find any obstructions remove them. Remove the cable from the cork.
3. Using a hot glue gun, put a ring of glue on the bottom of the nut and attach it the small end of the cork. Make sure that the hole in the nut aligns with the hole in cork.
The cork and nut are now attached as shown in the fourth image. The LED will stick up through the cork and within the center of the nut. The crystal will stand on the top of the nut.
Add Comment
