3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Powered Mystic Light
Step 8Final assembly - almost done!
This is the penultimate step - you're almost done!
1. Using a metal file, make a small notch into the bottom of the copper fitting.  Remove just enough of the pipe for the USB cable to comfortably fit in the groove.
2. To make sure that you've made the groove large enough, put the cable into the fitting as shown in the second image and make sure that the fitting sits completely flat on a smooth surface.  Remove the LED cable from the fitting.
3. Gently push the LED and cable through the hole in the cork until the LED is inside the nut but not poking out of the top as shown in the third image.
4. Take the cork/nut/LED cable assembly and insert it into the copper pipe fitting as shown in the fourth image.
5. Apply power to see what it looks like without the crystal.  It should look like the last image for this step.  Pretty cool, huh?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:talk2bruce
