Remove these ads by
Signing UpStep 1Buy parts
1. A 1 farad 5.5 volt super capacitor
2. A male USB connector. (You can cut a USB adaptor and use only the red and black wires or + and - connections
3. A normally open push button switch
4. (Optional) A toggle switch
5. A perf board or etched circuit board
6. A Led any LED works as long as it is not above 4.5 volts. Preferably with built in resistor. You can also use this color changing LED
7. A resistor if your led does not have one.
8. Wires if you are using a perf board
9. A usb charger. (You may be able to use a computer USB port but I don't take any responsibility for any damages to your equipment.)
Most of the parts can be bought from http://allelectronics.com. They have the very best prices that I have seen so far.
if you're saying this will last for ~hour then my formula doesn't jive well. Am i missing something else here?
1 hour = 60 minutes = 3600 seconds,
1000ma / 3600 = ~.30 mA per second. i don't know any LED's that will light up at all with that little current...
thanks!
Can everybody please rate my instructable so I know how I am doing. Thanks.
The problem will appear if you wire them in series: you'll surely have more voltage, but here the capacitance will be hugely reduced...
Have you thought of replacing the capacitor with a CMOS baterry? Little changes in the setup and will last a lot longer and can add another LED. What about a picture of the backside. With a 1 foot long cable can be used to light the keyboard while connected to the laptop.(for those times you are in bed and do not want to disturb your roommate). Once encased, just push the cable inside of it with theplug, Both will be protected at the same time, more transportable,
http://www.instructables.com/id/Battery-Free%2c-USB-Powered-LED-Torch/
I even do all the calculations for you to work out charging and use times!
