3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Safe
USB Safe
Want to protect valuable files? or keep sensitive information way from peering eyes? Or you could even attach your keyboard and mouse and lock your computer!
Step 1Materials and Supplies
Materials needed:
-Exterior PVC Electrical Box w/ one/two 1/2 inch opening
-3 inches of 1/2 inch PVC pipe (if box has 2 openings)
-1/2 inch cap (if box has 2 openings)
-USB extension cable (I bought mine here)
-Keyed Switch (I bought mine here
-USB flash drive* (must be short. I recommend this)
-4 screws
-PVC box cover
-(optional) Expanding Foam
Tools Needed:
-/Hot Glue Gun
-/Drill
-/Soldering Iron and Solder
-/Wire Strippers
*only if your making a "safe." If your making a usb device lock, you do not need this
84 comments
1-40 of 84next »
Oct 3, 2008. 1:07 PMgrue says:
there's a VERY BIG problem with this idea, from the pictures, the box has a 2 cm hole! so a theif can just yank it out of the hole. and haven't you people heard of an angle grinder? they can cut open the box in less than 5 min just telling you
May 25, 2009. 10:24 PMmage says:
if you just let strangers walk into your house with angle grinders then you have no busniess with safes
Dec 14, 2009. 8:51 AMzack247 says:
and if someone broke into your house with an angle grinder at night, if you don't have home security, i think you will be woken up by the squealing noise that comes from the grinder grinding through your safe. besides, who would go through all that trouble for a flash drive?
Jan 7, 2009. 3:11 PMmettaurlover says:
i'd, for encryption in case of removal, if this would work, intentionally misalign the wires in the extension cord so that they sent reversed signals, ie a "1" sent to the drive will actually be read as a "0" if it is removed from the extension cable. best way to encrypt the things that i know of!
Nov 2, 2008. 8:01 AMstruckbyanarrow says:
domo!!!!!!!!!!!!!!!!!!!!
Oct 29, 2008. 11:15 AMcooldude375 says:
instead of using plastic box inside of safe or something like that why dont u just make a metal box to begin with
Oct 22, 2008. 12:46 AMmage says:
then put it in a safe and weld it shut after drilling a hole in the side and running cat5 through it. then bury it in your backyard where it will remain until the end of time
Nov 16, 2008. 2:38 PMCartuner55 says:
But time never ends so thats impossible.
Dec 2, 2008. 4:52 PMxproplayer says:
well then it will last forever
Dec 2, 2008. 5:07 PMCartuner55 says:
when does forever end? :P just kidding :D
Sep 23, 2009. 8:39 AMhbio says:
i don't think that this was designed to be super secure. It is just something to discourage people from reading your files. This is still very cool though and this is probably something that i would enjoy making.
Sep 21, 2009. 3:42 PMMACKattacksnipe says:
Just Finished With a hard drive
Jul 25, 2009. 9:36 AMjoezero says:
I have seen something similar to this made with some differences: It had been built into a cheap fireproof document safe. Insulated pins through the case to ensure fire rating retention and connect drive. Bolted to floor from inside safe. Some remake thoughts: (just thoughts and perhaps not good or safe ones) A destructive backup plan (if I cant have it they cant either) install flash drive in a unplugged copper tube with model rocket engines perhaps. tilt or accelerometer to determine if compromised wind up flash light dynamo to power up the internals a way to make it simplistically proprietary and one-of thus reducing hacking to the skilled only (if it uses four matchbox cars for plugs where you gonna get one of those?) Keep a wood elf with a chain saw in there. he"s gonna be pist when the door opens.
May 29, 2009. 9:17 AMwcgems says:
Cool Idea. I was thinking about seeing if you could find a USB Hub that would allow you to fit several in there at one time. That would be cool.
Aug 5, 2008. 12:20 PMHwolfw says:
I think that instead of using the ground on the switch, use the +5 V power to eliminate the "device malfunction" pop up
Oct 5, 2008. 11:49 AMDavidRobertson says:
use a DPDT key switch for power and data ground
Apr 17, 2009. 4:40 PMPCfreak says:
Usb cable has no data gnd
bcuz its just a comm. line
red=5V+
green=data recive
white=data send
black=GND
Apr 19, 2009. 2:19 PMzapro says:
Stop saying that stuff, it's WRONG! The green is Data+ and the White is Data-. USB is a bi-directional data bus where the host and slave takes turn on transmitting data over the USB data pair. The Green wire goes positive, when the white goes negative, and vice versa. This system is called "differential signalling" and makes the signal more noise immune.
Apr 23, 2009. 12:47 AMPCfreak says:
i took a computer class in high school and they told us that the data has no ground but i guess i learned something new thx zapro
Dec 29, 2008. 4:05 PMMighty Mackinac says:
so...would be it possible to just put a regular hard drive in it?...just find a sata and power cable long enough to hide it some where... but where you put the lock? power or data?
Dec 31, 2008. 9:28 AMMighty Mackinac says:
well there is a registry edit that can be done to "hide" harddrives that are connected on any port...it might be possible...but you might want to just unmount it before you turn the key...just to be safe...using an eSata might work the best...those are meant to be removed and unmounted from the machine...
Nov 25, 2008. 11:07 PMstevenleeblount says:
Get a large enough metal box and put a ecternal harddrive in it
Oct 21, 2008. 4:46 PMamature engineer says:
Cool.
Oct 1, 2008. 6:21 AMmunchman says:
There is really only one word to sum up this project: super-awesome-insanely-cool-I'm-gonna-build-this (It's a real word - look it up) Honestly mate, this is fantastic! Favorited, 4 starred, and going to be made.
Oct 1, 2008. 6:26 AMmunchman says:
Actually, make that 41/2 starred
Aug 18, 2008. 1:06 PMMACKattacksnipe says:
now im going to try it with a external hard drive
Sep 28, 2008. 5:09 PMmage says:
yeah, just get a bigger box and wire the usb extension the same way
Aug 9, 2008. 2:50 PMrocketman221 says:
use security screws on the box. that would make it much harder to open because you would need a special screwdriver
Sep 20, 2008. 9:04 AMosgeld says:
or a hacksaw
Mar 18, 2008. 3:54 AMrelay says:
you should see the [http://https://www.ironkey.com Iron Key] . it is filled with epoxy and if it detects that you are trying to hack it, it will self destruct. unfortunately I don't think it actually explodes, it would be cool if it did.
Sep 17, 2008. 4:55 PMjeymeowmix says:
would be awesome though - "wrong password?! OH SHI- -mushroom cloud-
Aug 31, 2008. 3:42 AMPCfreak says:
thanks for making this instructible but have you tried modding an old floppy drive case? i know i have its way cool
Feb 6, 2008. 11:48 AMgamer says:
does this work, cause the data pins are connected directly to the 5 volt supplied from usb i dont really get how this is possible, but... i think the best way to do it is to cut only the black wire and put the keyswitch between it, anyways. nice idea! -gamer
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:Padlock(Kevin Latimer.com)
Philosophical, by personality. Inquisitive, by nature. Intellectual, by birth.
