3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Sensor Bar
USB Sensor Bar
This is how to make a sensor bar that can be used with a Wiimote and has a usb interface. It works fine with the Wii as well as the PC while using a program that allows to use the wiimote as a joystick (such as Glovepie) and is compatable with IR tracking.
Assembly is simple and can be done by anyone. For this instructable I used Legos to house the wires and LEDs, but anything that will fit them will work.
Step 1Supplies
For this project you will need:
4 infrared LEDs
1 USB cable
Electrical tape (optional)
wire cutter
wire stripper (optional)
something to house the LEDs and connections
and you will also need wire and a soldering iron OR 5 alligator clips.
If you use alligator clips it makes making the connections easier, but it will be harder to place it in a compact case.
29 comments
Mar 23, 2012. 12:01 PMCastelo Branco says:
This is my version of the wii bar. I builded it using some aluminum bars (the leftover of my pedalboard hard case). Is also USB powered and looks good with my iMac.
Jun 17, 2009. 4:32 AMmariosmash55 says:
Did the USB - powered energy short out the LEDs' ???
I was testing mine and it killed the LED.
Do I need a resistor or more LEDs????
Nice instructable by the way =)
Oct 13, 2011. 11:34 AMnodoubtman says:
Remember that usb can produce 5 V and 100 mA not more... so your resistor value should be : 5 V - Vled / A
let's say you have a led 1.4 V and 20 mA should do that :
5 - 1.4 V / 0.20 =180 - 220 Ohms resistor
see that page : http://ledcalc.com/#calc
thank you! :)
Have a great day! :)
Apr 20, 2011. 12:33 AMhondaman900 says:
Nice instructable. Well laid out. There's a more developed version of this on Kickstarter http://www.kickstarter.com/projects/1621263610/the-megabar-free-your-wiitm Seems to be a more complete system. I like their father-son kit idea.
Oct 17, 2010. 1:57 PMaccount3r2 says:
if i have 4 2.8v leds, what amount of voltage would i need if i used batteries?
Oct 18, 2010. 5:17 PMaccount3r2 says:
im using these
Oct 18, 2010. 5:13 PMaccount3r2 says:
i might use a supercap instead because it is rechargeable then use a female usb plug and when i want to charge it i plug the cord it.
Oct 17, 2010. 1:51 PMaccount3r2 says:
what voltage leds do i use? please reply soon
Jul 2, 2010. 8:32 PMryvie says:
do u need resistor on the wire?? thx
Nov 19, 2009. 1:02 PMsmrtcar says:
Can I not just use a cordless wii sensor bar with batteries attached?
http://nintendo.about.com/od/accessories/fr/nyko_wireless_sensor_bar.htm
Just asking... :)
Aug 15, 2009. 2:23 PMdharc789 says:
What about if you wanted to use 4 AA batteries as well with the USB. Would the 100 Ohm resistor still work. I have been trying to figure this out. Using 4AA batteries (6V) calls for a 15 Ohm resister and for a USB (5V) it calls for a 2.2 Ohm. Could you use 100 Ohm resister to cover both??
Aug 18, 2009. 5:45 PMdharc789 says:
Here is a drawing I'm was thinking about. I think it would work. But wanted to confirm.
Aug 18, 2009. 10:39 AMColonel88 says:
first of all, what does this sensor bar even do? does it connect ot the wii to receive wii remote signals or something? Because i don't understand what it is supposed to do. but if it is used to illuminate infrared camras, then it is awesome. Please reply
Jun 20, 2009. 5:33 PMl4nd0fc0nfu510n says:
I can't get mine to work with GlovePIE. How do I make it detect that I have an IR sensor plugged in?
Jun 21, 2009. 5:45 PMl4nd0fc0nfu510n says:
THANKS! Excellent instructable!!
Jun 19, 2009. 4:31 PMl4nd0fc0nfu510n says:
(removed by author or community request)
Jun 20, 2009. 4:24 PMl4nd0fc0nfu510n says:
Nevermind sorry, I bought a 4th. Instructable works great! Thanks!
May 2, 2009. 9:52 PMReCreate says:
I always thought of making myself this,I planned to buy a sensorbar on ebay and mod it to connect to the usb port
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:oniGamemaster
