Step 3Making the connections
If you are using alligator clips all you have to do is clip them on. Simple.
If you are new to soldering, make sure you have a damp sponge to keep the tip of the iron clean. Also be extremely careful not to touch any of the medal. I recommend soldering over cardboard that way if any solder touches it it won't stick easy. Just simply touch the wires together, put solder to it, and melt it with the soldering iron. The solder should stick to the wires. Also, try not to inhale the smoke.
Add Comment
