3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Stretchy Fabric Connection
Step 3Ironing conductive traces
  • last photo ←
Fuse (iron-on) some interfacing to a strip of stretch conductive fabric. Cut this strip into 5mm thin strips. Enough so that you have 4x (or 5x, including ground) the length of the connection you want to make, in my case 30cm long, although I'm not sure if the resistance over a longer distance will effect the USB connection and it might not work. Will also try out in future versions.
Lay out your piece of regular stretch fabric on an ironing board or other good ironing surface. Iron it flat, and then fuse (iron-on) your conductive strips so that they go from one end to the other with about 5mm spacing in between.
The resistance for a 5mm thin strip over 30 cm seems to be about 60 Ohm. You can actually about half the resistance by making the strip twice as wide (1cm).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
345
Author:Plusea
