Introduction: USB Thumb Drive Pocket Knife
In this instructables I'm going to show you how to construct a USB thumb drive (memory stick) pocket knife.
Here are all the materials you're going to need to make this project:
1. USB thumb drive (any storage amount will work)
2. Swiss army pocket knife
3. Hot glue gun and glue
4. Small flat head screw driver
Step 1: STEP: 1
Beginning this project you'll need to remove the tweezer and tooth pick from the knife.
Then insert a flat head screw driver into the opening where the tweezers or tooth pick goes. (This will be the back of the knife.) Carefully use your screw driver as a lever and push down on it; in turn this will "pry" the handle from the knife.
Only pry one side of your knife handle and leave the other handle intact.
Step 2: STEP: 2
Now that you have removed one of the handles from the knife, run a dab of hot glue along the edges of the handle then place it on the thumb drive. Then hot glue your next handle on the opposite side of the thumb drive. This will sandwich the thumb drive between the two handles.
Be sure that you don't glue the guts of the knife together.
Step 3: STEP: 3 Final Step
Now you have a portable USB thumb drive pocket knife, which you can take with you where ever you go.
Bellow this is what the finished project should look like.
Hope you enjoyed this instructables!
*You are responsible for the handling of this knife.
Instructables Design Competition
Pocket Sized Contest
