loading
Step 22: ATTACH THE REED SWITCHES
Experiment With Positioning
Unless you have worked with reed switches before, it may be tricky to find the appropriate place to attach them to your typewriter.  So, some experimentation with a multimeter is required before finalizing the position of each reed switch.  First, attach a magnet to the key you wish to detect (for example, the spacebar, backspace key, shift key, or return carriage lever).  Next, attach the probes of your multimeter to the wires of the reed switch, and use the "continuity" setting (often signified by a little beeping sound wave) to monitor whether the reed switch is open or closed (see picture above).  The multimeter will emit a beeping noise whenever the switch is closed (i.e. when a magnet is nearby).
HINT: The reed switch can detect magnets in any direction, but it is most sensitive to magnets that are directly in front of it or behind it (see 2nd picture above).
Finalize the Position
When you are satisfied that you have found a good position for the reed switch, so that it opens and closes consistently whenever the key is pressed, use superglue to attach it permanently to the chassis of the typewriter.  I like to use hot glue as well -- not to attach the reed switch but to tack the wires down.
Example -- Space Bar
In the example shown above (see 3rd picture), the switch is normally open, but closes whenever the space-bar is pressed.  However, you may decide to use the opposite configuration -- so that the switch is normally closed but opens when the key is pressed.  It makes no difference whether the switch is normally open or normally closed, because the software is able to figure this out during calibration.
I'm a writer and I **LOVE** the idea of this - I've often windered if there were a way to retrofit my old typewriters tfor use with a PC. However, I'm unclear about how keys like "Alt" and "Ctrl" work - they're not present on a typewriter, are they? You mention them as being "hard wired" in one of the steps, but I'm not sure how this actually works in practice. Also, I assume this hack will allow for "Shift+key" commands for caps, differing punctuation, etc.? Also, I'm also assuming that (since they're not at all present) that there's no way to assign "F" keys via some sort of key combination in the calibration stage? Of course, it's not at all hard to just have a second, actual keyboard plugged into a second USB port for the times you need an "F" key. Last, I'm pretty sure they do, but when the typewriter is manipulated, the keys still articulate and strike the drum, the carriage still lifts and slides to the right, etc. yes? Thanks!
Ctrl and Alt are buttons on the circuit board itself. You can also wire them up to other random adjustment knobs and switches on the typewriter. There is also a "Fn" button on the PCB that allows you to access a secondary key map, so that the numerals become F-keys, the lower right of the keyboard becomes arrow keys, and so on.
So if they're on the circuit board, how are they manipulated? Can one use a momentary switch, perhaps, attached to the typewriter chassis? How have you historically accomplished this, or have you just not bothered? Thanks!
<p>Hello, Thank you for this wonderful Tutoriel. I am using V2.0 of your design files. Unlickly I can not access the source code files. Can you update the link please?</p><p>Thank you</p>
<p>What if I wanted to go the opposite direction &amp; feed a mechanical USB/PS2 keyboard signals into the board of an electronic typewriter?</p>
<p>One of the best ideas I've seen here at Instructables. Thanks for sharing!</p>
<p>my typewriter doesnt have a crossbar :( what do i do?? its a remington. but i have no idea which model it is..</p>
<p>This method of typing is second only to the <a href="http://en.wikipedia.org/wiki/Model_M_keyboard" rel="nofollow">IBM Model M</a>. Excellent work, now if only I can get my hands on a typewriter...</p>
I cut the sensor board so that the small ' scrap ' piece has the four holes on the end. is this a problem, or can i go ahead and solder?
Oh, yeah you definitely need those holes. I will send a replacement board. Message me privately with your address.
A really great idea! Does anybody have experience regarding compatibility with Brother manual typewriters? I would really like to upgrade my dad's old one.
If any keys are missed, well you could always use the onscreen keyboard on rare occasions..it's so worth it for this.
Thanks! Actually, on an iPad, ALT+any key produces some pretty wild results -- many oddball characters can be accesed that way, too. And you can program the Interface Board's &quot;bonus&quot; key to access another keyboard's worth of hidden extra keys.
Also, orientation of the magnet is also important. <br>http://www.kjmagnetics.com/blog.asp?p=reed-switches-and-hall-effect-sensors
Which pin would I connect the space bar to the USB Interface board?
Sorry, D! I am seriously upgrading my website and this instructable this week, so some files are getting shuffled around and links are temporarily broken. The pairs of pins labeled D7 D8 etc are the ones you can connect things like space bar and backspace to. The pins labeled &quot;chassis&quot; on the board is where the chassis wire goes to -- Im not sure what it is called on the schematic.
So I follow the labeling on the USB interface board? The instructions here are out dated.<br><br>Thanks.
I know -- I am seriously updating them right now. The new kit has breakout boards for each reed switch so they cannot break, and eyelets for attaching the chassis connection instead of using a loop of wire. The revised instructions will also be clearer with more pictures and specific examples from various typewriters (I just upgraded my photo setup). This is a long overdue upgrade that will go live this weekend. If you would like me to send you the new components, let me know and I'll send it to you at no charge.
Cool. Looking forward to it!
I remember you had a video about the reed switch which involved using a lighter. Where is that?
here: http://youtu.be/EazIWCGevv0
Hey man that is really cool, i have an old Type Wrighter some were in my attic im thinking about doing this thanks man
Um, they are manipulated by pressing the buttons. I usually mount the <strong><a href="http://www.spriceangels.com/Touch-Screen-Stylus_105_1.htm">Touch Screen Stylus</a></strong><br> on the side of the device, so the buttons can be reached with the left hand while typing. You could of course mount your own buttons somewhere. Every typewriter is different -- that's why its a fun project!
Christmas listed!
Wow, this is awsome, very clean!
wow that is awesome! It looks nice and clean, my uncle and I tried to make one, but it was very messy :/
wow this is just amazing if i used a frontal surface mirror i coulld make a cool liltle decoreten
so nice I do like to do try it<br>but the mini pc is how much?<br><a href="http://www.topusbdrive.com/custom-usb-c-1.html">http://www.topusbdrive.com/custom-usb-c-1.html</a>
is there a way to turn it into a printer for the writing projects on your computer?
This is really slick!
Amost as cool as the using a Selectric typewriter as a printer a friend did in the 1975-76 time frame. Wirt Atmar of AI Cybernetic Systems in Las Cruses NM did the hack and drove all the solenoids that punched the keys on the selectric with his Altair 8800 (Or was it an IMSAI ... my minds details goes after a while :) ... But his was an output device and this is a neat input device! .. I wish I had a picture of his old hack to share with you.
Whew! An ambitious project for your friend to tackle back in the mid-70's... Of course, by then, IBM had long since made a basic, hard-copy-only computer terminal from their own Selectric line, the &quot;2741&quot;, to replace the almost-universal (but deathly-slow) &quot;Teletype ASR-33&quot;. The 2741, with a few variants, was still geting some use right on through the early 80's! <br> <br>The &quot;personal computer revolution&quot; must be credited to both Altair, who &quot;made the ball&quot;, so to speak, with their &quot;8800&quot;, and IMSAI, who &quot;got it rolling&quot; with their &quot;8080&quot;. As far as I know, both used the same INTEL &quot;8080&quot; processor, virtually the only &quot;micro&quot; in existence at the time. By adopting as &quot;standard&quot; many of the features of the Altair while improving significantly on their design, IMSAI helped create much of the market they both then, brielfy, supplied. (Altair's only real &quot;advantage&quot; was Bill Gates' BASIC, quite possibly one of the last pieces of software Bill can LEGITIMATELY claim to have WRITTEN HIMSELF...)
Thanks -- that sound like a cool project. Tom Igoe also did a similar thing recently. Don't tell your friend Wirt, but there are many electric typewriters, especially those made by Brother, that have RS-232 ports, and can work as printers already.
In 1976/77 (the heyday of the Altair/IMSAI) there was no such thing as a typewriter an with RS232 port, per se. The closest thing was a teletype.
thats a neat idea
je je thanks for translating for irenvj :)
I wonder if anyone has tried to sniff or emulate the iPad keyboard protocol yet. It would be nice if we could get the Arduino chip to connect directly to the ipad and skip the camera connector. <br><br>Of course the result will be less flexible but the USB connector is an expensive accessory.
Maybe you could hack something like <a href="http://www.dealextreme.com/details.dx/sku.44443">this.</a>
Yeah, it would probably be easier to take a part and try to either duplicate or just mod. But at $40 it really pushes the threshold of just buying a cheap BT keyboard to work with. <br><br>Ebay/sparkfun doesn't seem to have bluetooth breakout boards with HID support wonder why =\
True, that price is a little high just to hack apart, isn't it?
Yeah, I wonder why Apple designed it that way...
I have zero soldering experience save for some ill-fated stained glass projects in high school. However, I've been tinkering around with soft circuitry lately, and in so doing learned of the existence of conductive epoxy. I haven't used any yet myself. Is there any reason I could not use conductive epoxy in place of solder in this project?
I don't think it's a good idea to use conductive epoxy on this project. However its not terribly difficult with good old solder. Its quite easy if you have the right teacher. Why don't you find a friend to help you out? Are there any hackerspaces in your hood (check hackerspaces.org)? I'm sure they'd love to help.
About This Instructable
190,038views
421favorites
License:
More by jackzylkin:Installing USB Typewriter Conversion Kit for Corona and Smith-Corona Typewriters Installing USB Typewriter Kit on Olivetti Typewriters Retrofit an Antique Scroll Saw to Use Modern Blades
Add instructable to:
