3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Typewriter
Step 9ATTACH FLEXIBLE CONTACTS
Into each of the solder holes you have marked on the sensor board in Sharpie pen, insert one flexible contact and solder it in place.  If a mark falls between two holes, simply choose the hole that the mark is closest to.
Take a second to look at the second picture shown above. You will see a common situation -- the board has been cut in such a way that some of the contacts are not connected to a shift register at all.  In this case, you need only solder a jumper wire between these unconnected contacts and any of the unused pins on the rest of the Sensor Board.
IMPORTANT: In 99% of the cases, you will want to attach the contacts so they stick out underneath the Sensor Board (i.e. on the opposite side from the chips).  However if you have a Royal typewriter, you will want to go about things differently.  Please read this note about Royal Typewriters before continuing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:jackzylkin(USB Typewriter)
