3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Voltage and Current Tester!! (version 1)
**NEW VERSION IS UP!!!**
http://www.instructables.com/id/USB_Voltage_and_Current_Tester_version_2/
Since it's sometimes necessary to check your USB ports for voltage or if you are curious on what kind of Current draw your devices might be pulling, it would be great to have something to check these.
Now you can.
Instead of just hacking apart USB cables and checking these readings with a Multimeter or one of the Pen Drive style voltage checkers, this instructable will give you a tool that is painless to use.
Moving onward.....
*PLEASE RATE & COMMENT*
Step 1Parts!
Parts!
Sorry,
The pics for this step did NOT turn out.
What you need:
Soldering Iron & solder (duh)
Epoxy, aquarium sealant or hit glue (optional)
Foam
1 PC Bay Cover any size will do
3 finishing nails or similar items to make into "posts"
1 USB Extender cable, or pieces from other projects ;)
1 Binder or Bankers Clip shown below. (unpainted)
It might not be a bad idea to coat the handles of the clip with a rubber coating, something along the lines of PLASTIDIP.
19 comments
May 3, 2011. 6:03 AMinhaos says:
USB voltage and current test is truely not easy.Here is a perfect solution:http://www.inhaos.com/product_info.php?products_id=28
The product will be laucned in June.
You can buy it very easily on EBAY.
Good luck!!!
Jan 17, 2010. 4:14 PMmattccc says:
do you know how much current a ipod touch or iphone draws
Dec 19, 2008. 3:34 PMKoil_1 says:
Actually you would need something plugged into it to test the amperage draw. And just a thought, it might be pretty easy to get a small switch to replace the bankers clip. You could also cut the lip of a bay cover and glue that to the back just for a better aesthetic appeal. Over all I would have to say this is a pretty great idea and I'm definitely going to build something simular. Thanks for the Instuctable.
Dec 18, 2008. 6:45 PMkraM says:
thats a pretty good idea, looking forwerd to the mini version
Dec 18, 2008. 8:13 AMnubie says:
This is pretty cool. My take is that you can get Digital Multi-Meters from Harbor Freight for $3 apiece, so you could have a meter with built in USB lead from Dollar Tree. Project Cost: $4. :) (or you could splurge on dual DMMs and pay $7 to get voltage and current measurements) Awesome.
Dec 17, 2008. 10:41 PMChiana_Rei says:
I like this, now if I could add in a lcd and mode selector, to view voltage and other such info, that would be even cooler, of course so would a million dollars.
Dec 17, 2008. 12:07 PMjakdedert says:
I think this is a good idea, but some potential for shorting your USB port exists. Perhaps you could recess the test points and use a SPDT switch to break the line for the current measurement. I don't think it would be all that much more difficult to build, and would be more compact. For example, a scrap of pcb could be glued inside the housing, with holes drilled for access...or for a more robust device, a simple pcb could be etched with three pads for test purposes and solder pads for the switch.
Dec 17, 2008. 7:04 AMmrmath says:
Suggestion: Step 2a-Test to make sure all connections are good. Now's the time to fix a bad connection, not AFTER it's been epoxied to death.
Dec 17, 2008. 7:59 AMPKM says:
Second suggestion- instead of epoxy, melt a wax candle into the space. You can remelt it to remove it (might not be pretty, but it can be done) and I'm pretty sure it's cheaper than a whole tube of epoxy. Smells better, too. It's not quite as strong, but if it's only meant to stop short circuits or connections working loose it will do fine.
Dec 17, 2008. 7:18 AMlasertech says:
Another fine project!!! I WANT!!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:gmgfarrand
Ex-Navy Gunner Learned to repair I.T. equipment because nobody local knew what the hell they were doing!
