Remove these ads by
Signing UpStep 1Parts and Tools
wire strippers
wire cutters
soldering iron and solder
electrical tape(optional)
Parts:
5 leds
5 100 ohm resistors
4 position DIP switch
Momentary pushbutton
5 1k ohm resistors
one small piece of perfboard/veroboard/breadboard
13 long female header
assorted wire, 3+ colors would be good
USB cable, one end must be male/A(standard)
2 10k ohm resistors(optional)
light sensitive resistor(CDS photocell)(optional)
I find futurlec.com is also a cheap place for these parts, but shipping will take a few weeks.
Your other problem is that USB ports are current limited to 100ma each, until you plug in a recognised USB device, if that device needs more then 100ma to operate, the computer will then allow 500ma to pass from that port. As this is not a USB device, the computer will not recognise it, and as a result, the max current available from that port will be 100ma. So if you turn on all 5 LED's, assuming each one draws 20ma (often more) you will have exactly ZERO ma for your project.
So what does it do?
