USB Charger 9V
2,044
50
16
Published
Introduction: USB Charger 9V
Easy make portable USB charger
Step 1: Need
Need:
Case
lm7805 voltage regulator
batery clip
9V batery
USB
switch
pliers
soldering iron
glue gun
Step 2: Circuit
It's so EASY!!!
Step 3: Fold
Fold voltage regulator (lm7805) contacts
Step 4: Cut Wires
Cut wires from batery clip (4-5cm)
Step 5: Solder
Solder 2 black wires (from batery clip and witch cut off) to voltage regulator ground. Red wire (from batery clip) solder to voltage regulator input.
Step 6: Solder (part 2)
Red wire (witch cut off) solder to USB +. Black wire (witch cut off) solder to USB -.
Circuit is done!
Step 7: Cut Holes
With pliers cut holes to USB and switch.
Step 8: Glue It !
Glue USB and switch in holes. Voltage regulator glue to case wall.
Step 9: Done!
Enjoy and charge your device!
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    16 Comments
    Most smart phone batteries are 1500-3300mah.
    A 9V battery has 50-400mah and at 500mw load has less than 300mah capacity.
    You're also losing 30% of that 300mah thru the 7805 as heat.
    Just exactly HOW much does this remaining 210mah charge your phone ???
    Ref : http://www.powerstream.com/9V-Alkaline-tests.htm
    is this to charge the battery itself?
