3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB controlled mini lava lamps
Step 3Poor man's usb plug
Poor man\
I did not want to destroy the USB plugs on the lava lamps so that they could be used separately, and so that the USB lava lamp controller was modular (other devices could be used switched on and off instead of the lamps). If you disassembled an apple keyboard in the last step you would have have two female USB-A jacks that you can use, and so can skip this step. You could also purchase the female USB-A jacks from mouser or salvage ones from a spare USB hub. I chose however to go with a cheap and simple option - a simple USB jack made from some striped wire wrap (any thin wire would suffice), a bit of perfboard, and some paper and transparency film for insulation. Simply cut a bit of perfboard to go INSIDE the USB plugs, add wire through the holes so that inserting the plug will not pull them out and will allow them to contact the +5V and ground connectors in the plug (see the pinouts on the "Make circuit" step for which connection is which). Then cut some transparency film to cover one side of the board so the perfboard wire will not short out against the metal body of the plug. Jam this insulated board into the USB plug, and confirm with your multimeter that the wires make a good contact and are not shorting. These are how the USB lava lamps are connected to the circuit. For this project, make two of these poor man's plugs head-to-head on the same bit of perfboard (see the image). During the assembly step, you will see how the case holds both of the USB plugs on this connector.
2 comments
Jul 11, 2007. 11:00 AMJohn Whitlock says:
I didn't have much luck with the poor-man's USB plug - too prone to becoming disconnected. What worked like a charm was a PCI-card USB plate, often included in motherboard kits. We had a firm USB connection, and the other end was a female plug for a motherboard, making it trivial to insert our own wires. Also, I'm not sure an apple keyboard is a good bet - my current keyboard just has one LED, for the caps lock button, and this project requires at least two.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jamesh
