3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB hub storage unit in floppies!
Step 5Finishing the work
Finishing the work
Ok you the screw and the nut, now take the other floppy and make a hall with the iron solder in the disk. Put the screw and pass it all the way down to the bottom floppy. Try not to hit any cable. Ok now screw the nut and tight it .
Now glue if you have availble 4 rubber taps for more stability. I had just 2 and i cut them in half. the high is about 0,5cm.
Almost finihed. For more support special when the HUB is empty frm USB sticks, glue 2 wooded or plastic pieces at the bottom edges of the floppies
Your work is done....
Some Notices.....
Of course you may use in any way this portable unit. I highly recommend to use it wisely. A nice idea is to use the portable apps http://portableapps.com. Also you can put some OS for vary booting in the instructables.com you will find some ideas also. Some security appls.
Thank you all verry much for reading this instructable. I hope to find it helpful.
Sorry if the fotos are small resolution, are taken from my mobile phone.
The BMP drawings are now available!!!
ENJOY SUMMER i go for fishing!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:agis68
I like to invent and modify things. When i was 13 i fixed my dad's old Lancia Fulvia motor. I builded my first mod PC in 1991 using a mobo builded in a VCR box. I am first using all my inventions. I l...
more »
