USB Lights for Keyboard
5,127
112
5
Published
Introduction: USB Lights for Keyboard
This is a simple method of making a usb powered led lights to illuminate the laptop or PC keyboard while working in the dark.
Step 1: USB Male Pin
you can get a male USB pin from an old usb cable or dead pendrives. you can even buy a new usb male pin for very cheap price at electronic store.
Step 2: Attach Wires
solder two wires each of 15-20 cms in length to the first and the fourth pin. The first pin is 5v and the fourth pin is ground. we can use different coloured wires for each polarity, i used same coloured wire as only that was available with me.
Step 3: Cover It With Tape
use insulation tape of paper tape to cover the solder and protect the joints. This also provides a support to hold the usb pin
Step 4: Twist the Wires
Twist the two wires to avoid loose wires hanging
Step 5: Identify Polarity
If you used same coloured wire like me then use a multimeter to identify the positive and ground wires at the open end.
Step 6: Leds
connect two white leds in parallel keeping in note their positive and negative terminals. Connect a 47ohm resistor in series to protect the leds. Connect this setup to the two open ends of USB cable. Connect USB to laptop or PC and check if leds light.
Step 7: Support
use a 18 gauge copper wire as a support to the two wires and cover it with tape. this will ensure a firm support to the lights. Cover the whole setup with the tape to have a clean look.
Step 8: Completed :D
ENJOY !
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    THX! Very Useful.
    Should the resistor be connected to the positive wire?
    And between the LEDS (in parallel) and the wire (coming from the power source)?
    I can add putting some wrapped aluminum foil covered with duct tape around the LEDs to prevent them shining in your eyes at night, and to focus the light on the keyboard.
