Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
all this riff raff makes absolutely NO SENSE WHATSOEVER. i think what it_dont_work is referring to is the simple fact of ADDING an additional fuse to the 12 volt line as stated clearly "before accessory outlet". thats where the 10 amp fuse comes into play. its not eliminating the fuse its simply ADDING a second fuse between the fusebox and the outlet. i know for example: my 1986 volvo 740 wagon contains a SINGLE 10 amp fuse and that powers MULTIPLE accessories.(ie: radio as well as a few interior lights i dont have the diagram or fusebox cover in front of me right now its just an example) or 2 fuses controlling diffrent parts of the same accessory.
with that said adding an additional 10 amp fuse in line AFTER FUSE BOX BEFORE ACCESSORY OUTLET is simply a safe measure and i would do it myself. its a no brainer as to why and most electronic engineering books will explain why its important.
as to the lack of fuse to the USB OUTLET MODULE now i will say this guy is just plain stupid lol. as stated above: most usb adaptors do not have anything higher than a 2 amp fuse. wiring it DIRECTLY to 10 amps, im suprised it did not pop and throw sparks. again a fuse serves a DUAL purpose, one as a protector and secondly and MOST importantly, a CURRENT LIMITING DEVICE.
lets take my old harman kardon citation twelve amp for instance: it REQUIRES a 3 amp fuse in the line. what happened when i tossed in a 4 amp? spit a spark and i was damn lucky it survived.
even eliminating the second 10 amp fuse before the outlet and AFTER the fusebox and all associated accessories(which should also contain thier own fuses individually) simply adding a 1-2 amp fuse in line(whatever the ORIGINAL fuse specifies) AFTER the outlet and BEFORE the usb module would protect the circuit and usb devices from becoming fried, wiring harness issues and fires.
please note the all caps are the critical things to pay attention to not yelling.
that should clarify all this. otherwise its a nifty instructable just dangerous as a bare wire the way its written currently.
a fuse is not a current limiter.
if there's a fault in a device for example a dead short, current will flow to the maximum, therefore once the current exceed the fuse rating, the fuse will pop thus preventing any more damage to the device, or reduce the risk of fire or overheat!!!!!!!!!!
(BTW, I specifically looked for a circuit-protected USB power adapter. Some have fuses and some have circuit breakers. The biggest surprise was finding several expensive models that have no circuit protection at all. Buyer beware!)
Considering my car's circuit, adding an in-line fuse to your design costs $5. Better to spend a little for protection than to risk ruining expensive electronics.
But I guess it's ultimately your choice. Good luck! ;^)
http://www.amazon.de/12V-Ladeger%C3%A4t-Einbau-Montage-M%C3%B6bel/dp/B004G6S1GO/ref=pd_sim_sbs_sg_4
Besides, it's a hybrid = Ton's of batteries!
But I think if you drained the 12V by leaving your MP3 running all year you can get a jump off a passing moped, or charge it on a solar panel enough to boot the computer.
review/description
If you park your car in READY mode the engine will cycle on as needed to recharge the main traction battery, and the main traction battery will supply power to keep the 12v battery charged.
Have a look at http://priups.com. I use Richard's approach to draw power from the main traction battery and can verify that the engine keeps it nicely charged when in READY mode.
I have been using the USB power port to charge my cell while driving. Everything has been working great. The extra load on the12volt circuit I tapped into is only about 1 amp. I could put 4 or 5 of these on the same circuit before I would be worried about maxing it out.
I have taken my car into the dealership several times for regular maintenance. No one has mentioned anything to me about warranty or the like, so I'm guessing Toyota doesn't really care about the mod.
10/10
