iImage Information
Given the bulky nature of 12volt adapters for vehicles, I decided to integrate a USB power outlet in my 2010 Prius III. Although this mod is specific to my car, it can be applied to many cars, trucks, RV's, boats, ect.
Step 1Finding a location for the USB power plug
iImage Information
In the 2010 Prius III there is an unused outlet next to the 12volt aux power in the front center console. I disassembled the center console and removed the plastic housing of the blank outlet and the 12volt aux.
(BTW, I specifically looked for a circuit-protected USB power adapter. Some have fuses and some have circuit breakers. The biggest surprise was finding several expensive models that have no circuit protection at all. Buyer beware!)
Considering my car's circuit, adding an in-line fuse to your design costs $5. Better to spend a little for protection than to risk ruining expensive electronics.
But I guess it's ultimately your choice. Good luck! ;^)
http://www.amazon.de/12V-Ladeger%C3%A4t-Einbau-Montage-M%C3%B6bel/dp/B004G6S1GO/ref=pd_sim_sbs_sg_4
Besides, it's a hybrid = Ton's of batteries!
But I think if you drained the 12V by leaving your MP3 running all year you can get a jump off a passing moped, or charge it on a solar panel enough to boot the computer.
review/description
If you park your car in READY mode the engine will cycle on as needed to recharge the main traction battery, and the main traction battery will supply power to keep the 12v battery charged.
Have a look at http://priups.com. I use Richard's approach to draw power from the main traction battery and can verify that the engine keeps it nicely charged when in READY mode.
I have been using the USB power port to charge my cell while driving. Everything has been working great. The extra load on the12volt circuit I tapped into is only about 1 amp. I could put 4 or 5 of these on the same circuit before I would be worried about maxing it out.
I have taken my car into the dealership several times for regular maintenance. No one has mentioned anything to me about warranty or the like, so I'm guessing Toyota doesn't really care about the mod.
10/10
