Add a USB Power Outlet in Your Car by rosenberger31
Featured
Given the bulky nature of 12volt adapters for vehicles, I decided to integrate a USB power outlet in my 2010 Prius III. Although this mod is specific to my car, it can be applied to many cars, trucks, RV's, boats, ect.
Step 1: Finding a location for the USB power plug
In the 2010 Prius III there is an unused outlet next to the 12volt aux power in the front center console. I disassembled the center console and removed the plastic housing of the blank outlet and the 12volt aux.
1-40 of 45Next »
walkerman1980 says: Jun 28, 2012. 3:39 PM
guys,
all this riff raff makes absolutely NO SENSE WHATSOEVER. i think what it_dont_work is referring to is the simple fact of ADDING an additional fuse to the 12 volt line as stated clearly "before accessory outlet". thats where the 10 amp fuse comes into play. its not eliminating the fuse its simply ADDING a second fuse between the fusebox and the outlet. i know for example: my 1986 volvo 740 wagon contains a SINGLE 10 amp fuse and that powers MULTIPLE accessories.(ie: radio as well as a few interior lights i dont have the diagram or fusebox cover in front of me right now its just an example) or 2 fuses controlling diffrent parts of the same accessory.
with that said adding an additional 10 amp fuse in line AFTER FUSE BOX BEFORE ACCESSORY OUTLET is simply a safe measure and i would do it myself. its a no brainer as to why and most electronic engineering books will explain why its important.
as to the lack of fuse to the USB OUTLET MODULE now i will say this guy is just plain stupid lol. as stated above: most usb adaptors do not have anything higher than a 2 amp fuse. wiring it DIRECTLY to 10 amps, im suprised it did not pop and throw sparks. again a fuse serves a DUAL purpose, one as a protector and secondly and MOST importantly, a CURRENT LIMITING DEVICE.
lets take my old harman kardon citation twelve amp for instance: it REQUIRES a 3 amp fuse in the line. what happened when i tossed in a 4 amp? spit a spark and i was damn lucky it survived.
even eliminating the second 10 amp fuse before the outlet and AFTER the fusebox and all associated accessories(which should also contain thier own fuses individually) simply adding a 1-2 amp fuse in line(whatever the ORIGINAL fuse specifies) AFTER the outlet and BEFORE the usb module would protect the circuit and usb devices from becoming fried, wiring harness issues and fires.
please note the all caps are the critical things to pay attention to not yelling.
that should clarify all this. otherwise its a nifty instructable just dangerous as a bare wire the way its written currently.
ARJOON says: Oct 5, 2012. 1:24 PM
lol wat are you talking about, a fuse will pop if a measured current exceeds its rating
a fuse is not a current limiter.
if there's a fault in a device for example a dead short, current will flow to the maximum, therefore once the current exceed the fuse rating, the fuse will pop thus preventing any more damage to the device, or reduce the risk of fire or overheat!!!!!!!!!!
bonzobuilder says: Jun 3, 2010. 3:31 PM
Great idea but execution lacks craftsmanship (eg, USB cut-outs looks like a literal hack job) and doesn't provide circuit protection. Perhaps a reasonable variation is to add an in-line fuse holder (http://www.napaonline.com/Search/Results.aspx?Ntt=in-line%20fuse&Ntk=Keyword&Nty=1&N=0)
alwaysworks says: Jun 3, 2010. 7:29 PM
There's no need for a fuse, it is just as protected as it was when the adapter was plugged  in to the socket.
bonzobuilder says: Jun 4, 2010. 12:16 PM
I don't know about the Prius but my car's cig lighter fuse is rated to 10 amps. My USB power adapter's 1 amp fuse will blow long before the car's 10 amp fuse.
(BTW, I specifically looked for a circuit-protected USB power adapter. Some have fuses and some have circuit breakers. The biggest surprise was finding several expensive models that have no circuit protection at all. Buyer beware!)
Considering my car's circuit, adding an in-line fuse to your design costs $5. Better to spend a little for protection than to risk ruining expensive electronics.
But I guess it's ultimately your choice. Good luck! ;^)
jgregory83 says: May 8, 2012. 6:35 AM
Yea, I fried a $500 GPS because of that. You made a very good point. Hopefully someone wont make the same mistake I did. Dont assume anything is protected. Its always better to have too much than not enough.
uberdum05 says: Jul 25, 2011. 8:59 AM
Most of the USB chargers available today have small SMD resettable fuses which are similar to what is on the arduino boards.
ILUsion says: Jun 4, 2010. 4:30 AM
Generally there is a need for a fuse, in the method shown here, all power is guided directly to the PCB so there is no direct protection except for the general fuse box in your car. In most car USB adapters, the fuse actually is the contact tip of the connector. By bypassing that, you will end up without a fuse. By putting a fuse near the charger, you have a better protection. Let's assume you get a short-circuit in the charger, so it gets an enormous amount of current. Your car's wiring can only sustain a certain maximal current so eventually they will burn (and according to Murphy's law they will burn at the one place where it is hard to get to, hard to notice and hard to replace). So expect quite a bill replacing these wires. With another fuse, only the fuse melts, you check/repair the charger (which is really easy because you have a fusebox in between), put in another fuse and there you go. All minimal cost and perfectly safe. Also for safety, I recommend NOT to put in a 10A fuse (like it_dont_work says). Putting a fuse with too high a value is not a good protection. Because actually a 10A fuse will not cut the circuit when you hit a peak current of 10A. It will only cut the circuit when you have pulled 10A for a longer period (let's say 2 hours). Or it will cut the current if you pull e.g. 15A for a short period of time (few seconds). If your USB charger pulls more than let's say 5A, there is something very wrong. A USB charger doesn't need 12V 10A (which is 120W, enough to power a notebook), according to USB specs, on the USB side you will get 5V 0.5A (2.5W); but let's assume your charge doesn't quite follow that and gives you about 5V 1A (5W) output. So limiting the fuse to, let's say 24W is generous (keep in mind, we need to be a bit generous: you still have to power the circuit that converts 12V to 5V and a circuit generally needs some headroom for variations in temperature, voltage swing, start-up, ...). So 24W on the 12V side, that's a 2 ampère fuse; which I think should be enough (I haven't tested it, but you could easily measure the current with a multimeter). Another way of determining what you might want to put, just take the fuse that came with the charger in the first place; you can safely assume the people who put the fuse there, knew the rules in choosing fuses.
hintss says: Jun 4, 2010. 12:38 AM
and the socket is plugged into a fuse. also, if I remember correctly, the USB chargers have built in fuses too...
it_dont_work says: Jun 4, 2010. 1:18 AM
the 12v line is fused in the fuse box of the car susualu (unless your cars from the 70's) and the 12v plug has a glass fuse inside the barrel. but another 10amp fuse would be a good aditive for a bit more piece of mind. when doing something like this you should add your own 10amp fuse on positive BEFORE is splits to the 12v plug and the usb to prevent too much current being drawn if your cars 12v line isnt fused, you dont want to pull too much power and cook the wiring loom, could be nasty.
mdshann says: Dec 14, 2010. 3:34 PM
A 10 amp fuse is way too high for this. Your car may have a 10 amp fuse for the 12 V outlet but your USB device only wants .5 amps or so. If you use a 10 amp fuse you will risk killing your USB device or causing a fire if something happens because a USB device will never need 120 Watts of power.
hintss says: Dec 14, 2010. 5:41 PM
exactly, so, 120 watts won't reach it.
jvan tonder says: Apr 20, 2011. 6:30 AM
You can buy a finished USB power adapter for this purpose for about 14 Euros on Amazon. No need to tinker:
http://www.amazon.de/12V-Ladeger%C3%A4t-Einbau-Montage-M%C3%B6bel/dp/B004G6S1GO/ref=pd_sim_sbs_sg_4
golddigger1559 says: Dec 20, 2010. 1:15 PM
isnt it fun making something just because you can?????????
conman says: Jun 4, 2010. 8:12 AM
So let me get this straight, you hacked a USB outlet in to your Prius so you could use your hacked USB cable? Instead of not chopping up your cable you bought, and using it with the manufacturer provided outlet 2 inches away? Sounds about right for this crowd. Nice instructable!
Achan20 says: Oct 25, 2010. 8:48 AM
but what happens when you need to charge your cell phone and power your GPS at the same time? lol
aed3810 says: Jun 22, 2010. 6:13 AM
Did you need to do anything to the power supply to the cigarette lighter or were you able to attach the wiring from the USB adapter straight to the live, ground and neutral of the lighter unit?
rosenberger31 (author) says: Jun 22, 2010. 8:04 AM
I just tapped into the cigarette lighters power. When the car is off, there is no power supplied to the accessory outlets, so the USB plug is powered off. (see step 6)
TanPotato says: Jun 7, 2010. 2:43 PM
The USB circuit will have a current limiter built into the IC for probably 1.5A max or so. There is no worry about it pulling too much current from its input.
moorea7 says: Jun 4, 2010. 8:27 AM
What I'd be tempted to do is hack a powered USB hub into the car by way of replacing the power supply with an appropriate DC-DC converter. I can get USB extension cables all over the place, so I could mount USB ports all over the car if I so wanted. I could then add a usb -> computer port on it so I can hook up a netbook and use the same hub for doing things like adding songs to the iPod. Also, with a little more trickery, you could add additional devices - ipod to car stereo comes to mind.
prodlad says: Oct 5, 2009. 8:22 AM
i would suggest adding a switch because the cigerette lighter in some cars is live all the time. So you could end up coming out to a car with a flat battery.
led235 says: Jun 3, 2010. 8:35 PM
 my car has 4 cigarette lighters, and a 120 volt plug in it, 2 cigarette lighters are onto the battery, the other two as well as the 120 volt plug are for the ignition.
natrinicle says: Jun 3, 2010. 8:26 PM
 I installed a 1.5 watt solar cell in my car because of the charger for my gps unit being live all the time.  The 1.5 watts seems to be enough to keep the battery from being drained, allows me to lazily leave my gps in the car, and only cost me $20.  I recommend it for everyone, and you can get a 5 watt model for just a little more if your setup demands it.
it_dont_work says: Jun 4, 2010. 1:20 AM
be great for me as i tend to leave my headlights left on, on dull days, nice idea fellow invader zim lover.
static says: Oct 7, 2009. 11:43 PM
 Not an issue because the dynex unit used auto powers off.
rosenberger31 (author) says: Oct 5, 2009. 9:36 AM
Almost all cars made within the last 15 years (especially foreign) do not power the aux/cigarette outlet when the car is off. I did not need a switch for this reason.
moorea7 says: Jun 4, 2010. 8:23 AM
Not true. In almost all cars I've been in, the cellphone charge cable stays functional even after the car is turned off.
prodlad says: Oct 5, 2009. 11:57 AM
well in britian some cars do, and pickup trucks and jeeps espically power there aux outlet.
zack247 says: Jun 3, 2010. 2:50 PM
my dads 04 ddge ram 1500 quad cab does, the neon lights he put in the air vents can be turned on if the truct is off. i think this is for fogligts or something
Padlock says: Oct 5, 2009. 5:45 PM
You would either would have to have one heck of a USB charger, a very tiny battery, or never ever use your car.
Besides, it's a hybrid = Ton's of batteries!
adaviel says: Oct 7, 2009. 4:32 PM
The 2007 Prius has a tiny 12V lead-acid battery to power the control computer, lights etc. The main battery is a 200V NiMh pack. I forget if the 12V will charge from the 200V without turning on the ignition; I think not. The ignition "switch" is a smart device that talks to the computer, which needs 12V to run. There is no way to charge the 500V from the 12V - f you somehow manage to drain the 500V one flat there is no way to jump-start or even bump-start the car; it has to be trucked to a dealer and the battery swapped out.
But I think if you drained the 12V by leaving your MP3 running all year you can get a jump off a passing moped, or charge it on a solar panel enough to boot the computer.
review/description
cjmapman says: Jun 3, 2010. 5:59 PM
Your Prius will not charge the 12v battery when it is off.
If you park your car in READY mode the engine will cycle on as needed to recharge the main traction battery, and the main traction battery will supply power to keep the 12v battery charged.
Have a look at http://priups.com.  I use Richard's approach to draw power from the main traction battery and can verify that the engine keeps it nicely charged when in READY mode.
Padlock says: Oct 8, 2009. 2:40 PM
The last part was kinda like a joke...
pirateaboard says: Jun 3, 2010. 2:29 PM
Looks good- my only recommendation would be to use a panel mount USB jack for a cleaner install.
Jayefuu says: Jun 3, 2010. 1:43 PM
Nice work! It could be prettier but all the detail is there in the ible to show people how to do it if they want to. You're right about this being better than the 12V plugs, they're SOOO bulky. 5* and a great first ible. :)
rosenberger31 (author) says: Jun 3, 2010. 12:27 PM
 Just wanted to give everyone an update....
I have been using the USB power port to charge my cell while driving. Everything has been working great. The extra load on the12volt circuit I tapped into is only about 1 amp. I could put 4 or 5 of these on the same circuit before I would be worried about maxing it out.
I have taken my car into the dealership several times for regular maintenance. No one has mentioned anything to me about warranty or the like, so I'm guessing Toyota doesn't really care about the mod.
ranex says: Oct 19, 2009. 8:29 PM
awesome- I've never thought of using the blank covers for mods- if you f-up you can get a replacement- i wonder if you can make a solder free way of hooking up the power to the adapter so you could remove the whole setup if you needed so no one accuses you of modding while it still being in manufacture's warranty- i might do this to my 1997 Volvo 850 wagon- i dont have to worry about warranty and it has a LOT of blank covers to put usb and/or a aux audio jack in
ranex says: Oct 19, 2009. 8:43 PM
a second note as well is that you could get a small usb hub and hookup several points around the car- a place for the kids to charge the ds in the back?- by making usb extention cables you could put the usb connection anywhere- inside center counsel - and make it convenient for you- but it might have more dash disassemble/ assembly
rosenberger31 (author) says: Oct 8, 2009. 5:01 PM
Thanks for the positive feedback everyone. I made Hack-A-Day! Not that this is really a complicated hack. Anyone with a cheap soldering iron can do this. I spent 1 afternoon on this, and most of the time spent was cutting the plastic from the back of the blank plug. I know the hole looks rough, but from the seats in the car, you really can't tell. A simple mod that almost anyone could do.
DWFMBA says: Oct 8, 2009. 7:49 AM
Thaaaaaanks!
1-40 of 45Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
