3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB powered LED/ Christmas lights
This shows how to power an LED or some Christmas lights from the USB port on your computer.
Step 1Get your materials
Get your materials
For this you will need the following:
Old USB cable with a male end (like an extender that you can buy at the dollar store)
An LED
OR
An old set of battery operated Christmas lights (also a dollar store product)
13 comments
Dec 7, 2010. 12:41 PMNaesDraw says:
Cool. I have one of these battery powered things. 4 AA? I think not. And this way, it will only be on when I'm sitting there. Thanks for the info.
May 1, 2009. 2:09 AMrickdf says:
Love the idea and effort but have to agree with Itsgoofytime. You really should add a resistor as they are cheap and easy. Just put one in the circuit and the led will last forever. Here's the formula. Good luck! //rick//
R = (VS - VL) / I
VS = supply voltage
VL = LED voltage (usually 2V, but 4V for blue and white LEDs)
I = LED current (e.g. 20mA), this must be less than the maximum permitted
Jun 23, 2008. 12:42 PMJontebullen says:
hey i followed your instructable (very nice btw) but my LED only blinks four times and then nothing. At first it was on more and the device manager thingy popped on and off installing it and stuff ( i run win xp ) but after a few reconnects it does nothing :( any ideas?
Apr 21, 2009. 6:36 PMsk83rjosh says:
it could also be that hes over powering the light maybe thats it it did it to me before i connected a resisitor but eventually the led will burn out sad but true i use my green led as a backlight to my xbox 360 lol works fine
Mar 27, 2009. 1:01 PMpdub77 says:
check out my first instructable that i posted over two years ago: usb Christmas lights.
you might also check out the link i provided showing where i got the idea from.
looks like we started at the same place. hope to see more from you.
Dec 19, 2008. 10:12 PMhoihoi151 says:
Add Resistor. Add Resistor Add Resistor. Add Resistor Add Resistor. Add Resistor
Dec 19, 2008. 8:51 AMwebman3802 says:
I just did this for a small tree on my desk at work. I used a 10-light battery powered string from the dollar store and a spare usb cable. Works great!
Dec 10, 2008. 11:34 PMagent9_11 says:
does it have to be battery operated ones or can you use regular ones?
Jun 17, 2008. 8:10 AMItsgoofytime says:
This is all wrong. USB puts out 5VDC, with a max of 500mA, which is close to blowing out the port. You need a resistor on the LED so it wont burn out, which is apparent in your LED picture. The LED appears to be yellow indicating a burning LED die. It should be green, as indicated by the green colored lens. Revise.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:supersith22
