3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB powered burner! this project can burn through plastics/ wood / paper(fun project also has to be very fine wood)
DO NOT MAKE THIS USING USB!!!! i found out that it can damage your computer from all the comments. my computer is fine tho. Use a 600ma 5v phone charger. i used this and it works fine and nothing can be damaged if u use a safety plug to stop power surges.!!!!!!!!!!!!!!!!!!!!!!!!!!!!
this project will be a usb powered and all you need is a usb wire, metal spring ( i got mine for a pen)/chicken wire(i have not tried chicken wire yet so it may not work.) and 2 croc clips or solder and soldering iron. When i project is complete it will be able to burn and cut plastic and paper and some very fine woods. this project is fun to make but be careful cause it can burn!! but its still pretty cool.
OK IN THE COMMENTS A LOT OF PEOPLE ARE WORRIED ABOUT BREAKING THERE COMPUTER SO IF YOU ARE TRY THIS.
IF you are worried about messing up your computer why not use an old phone charger or adopter.alll u gotta do is get a 5v or more phone charger cut of the top part which goes into the phone and use the red and black wire .(some times the black wires are white in chargers)ALWAYS REMEMBER TO USE A SAFETY ADOPTER WHEN USING MAINS ELECTRIC.
(SAFETY ADOPTER=ONE THAT SWITCHES OFF WHEN THEY IS ABOUT TO BE A SHORT CIRCUIT OR POWER SURG)
this will keep everything you are using safe and will stop you from destroying anything ELECTRICAL in your house.
Step 1Parts:
parts:
ok for this project you dont need very much.
part list :-
1 USB wire
2 Spring for a pen( not all will work, i think chicken wire also works, most fine metal wires do but not thick)
3 croc clips
4 soldering iron if u do not have croc clips
5 wire strippers and a computer to power the usb.
37 comments
Jun 15, 2009. 11:09 AMPyroMaster007 says:
oaky, so if i did this same thing, but soldered the wires onto a straightened paper clip, would the who paperclip heat up enough to become a wood burner?
May 17, 2011. 1:33 PMchriskarr says:
Well, I know it's been a couple years, but, to answer your question, no. Only the area between the contacts would heat up and, if the temperature was hot enough to efficiently burn wood, chances are the solder would melt before you had the chance to do much work. In reality, a good mechanical contact is the best option.
Oct 16, 2009. 4:16 PMColonel88 says:
Well i'm sure as hell that this thing will burn the jeebies out of yo' computer. And it will probably fry your phone charger too. Oh and change the name of the Instructable.
Dec 26, 2008. 5:07 AMyzzid says:
Hey, Nice...pretty downright simple..question though...dont we have to install ANY components, like resistors, pr what not? thanks! keep up the great work bro!
Dec 8, 2008. 5:54 PMled235 says:
Also, Nichrome Wire( used to electronicaly light fireworks) gets extremly hot. its foung in soldering irons! I think that the spring is still a great idea!
Nov 29, 2008. 6:14 PMraykholo says:
i used to do the same thing with lead from a mechanical pencil, but it snapped too easy i was gonna recommend nichrome wire but some one already mentioned it --- so running the current though steel wool also works in a similar way
Oct 22, 2008. 3:33 PMjunits15 says:
juts take the nickle crome wire out of a toaster and hook the thick wire to the wall it hets much hotter
Jun 20, 2008. 2:10 AMDELETED_evilfrogie says:
(removed by author or community request)
Sep 22, 2008. 11:23 AM98farhan94 says:
But your posting it on to this instructable?? Atleast have some common sense to post that link to the instructable relevant to yours!
Feb 22, 2008. 5:47 PMMatrixis says:
By reading the above comment I really don't think you know quite what you are talking about. You have a very basic knowledge of voltage, resistance, current and power. What you are doing is risky, yes, most computers do detect if it is drawing too much current and will shut the port down, some do not. The ones that do not, you will cause irripairable damage to your motherboard. For example. If we specify voltage is 4.5v and the spring has a resistance of 1 ohm, the current that the spring will try to draw is 4.5 Amps. If the spring is 10 ohm (very unlikely) is will draw 450mA (only just inside the safe current for a USB port) As a spring is just made of steel, it has very little resistance, so more likely to be close to 1 ohm than 10. If someone plugged this into a cheap powered hub, it is likely that the spring would get as much power as it wanted and get extremely hot, possibly burning out the hub or psu attached. DO THIS AT YOUR OWN RISK Measure the resistance of the spring... less than 10 ohms is very very bad
Apr 5, 2008. 7:43 AMdfd9 says:
"You have a very basic knowledge of voltage, resistance, current and power." OK, no need to spit it in someone's face.
Apr 5, 2008. 8:11 AMMatrixis says:
I feel that people who post Instructable have a good knowledge about what they are doing to reduce the risk to other people that may copy the project. What works on Their computer might destroy someone else's and the person doesn't have enough knowledge to successfully achieve this. I felt it neccesary to point this out to him that his knowledge on the subject is low and putting other peoples computers at risk. I'm sorry if being honest is offensive to you
Feb 22, 2008. 3:26 PMLinuxH4x0r says:
So, you ruin a $1000 computer just to save $5 for a foam cutter that does the same thing?
Mar 16, 2008. 11:36 AMcomputerwiz_222 says:
WRONG!! The voltage regulator IC on the circuit board of your mother board is rated for 500 ma per port. The spring is a piece of wire, it probably has a resistance of around .3 ohms. You are drawing a TON of current through USB. WAY OVER 500 ma. Not to mention that the gauge of wire used in USB cords is around 24 AWG. Eventually, the USB cord itself may become damaged. Trust me, I work in electronics. I repair laptops, desktops, stereo systems and just about anything else. If you don't believe me, look at the USB host chip on your motherboard and find a datasheet on it. Sure, it won't burn it out in 1 second, but over time, you will ruin it. It could go from an expected 200000 hour life to say 20 hours or less.
Feb 22, 2008. 3:34 PMLinuxH4x0r says:
Maybe not yours. But it is very possible Just sayin
Mar 13, 2008. 6:30 PMRetroPlayer says:
Please, before anyone actually attempts this, put a resistor in series with the wire! USB is meant to only supply 500mA per port, and sometimes THAT isn't even true. If you are in a non-powered hub, then the entire hub can only draw 500mA.
Not all computers, hubs, etc. are current limited. A short circuit essentially means less than 1 ohm resistance. Nichrome wire (or carbon) which is used as the heater element in most devices HAS a resistance. It might look like just a spring, but it is made of a special material. The resistance is what causes the heat. This poster's computer WILL break eventually, I can promise that.
You should *AT LEAST* have a 10 ohm resistance between the positive and ground. That will max you at 500mA. That's about 2.5W which your resistor needs to be able to handle. Most resistors people have are either 1/4 watt or 1/2 watt. Again, this is wire special wire is used: it can handle the wattage without burning up.
In short, this is a very bad idea and the poster is conveying his *personal experience* instead of knowledge. Again, it WILL break his computer soon, if it hasn't already. If you want to play with something like this, get some nichrome wire and make absolutely sure you can measure at least 10 ohms resistance.
Mar 13, 2008. 1:02 PMNirjuana says:
Dean-101, even thought the voltage is as low as 5 volts, this still can be very bad for your computer! Like Matrixis already said, if the resistance of your "cutter" is 1 ohm, you'll get 4,5-5 amps running trough the wire, and shorting that kind off amount isn't wise for anything. USB-ports can handle only 500 milliamp which is a half of a amp and you got 10 times that amount running. So if you don't want to break your computer, put at least 10 ohm resistor! And the whole idea of short-circuiting something that gets its power from computer is just plain stupid since computers are very sensitive. I think no-one should even try anything like this...
Feb 22, 2008. 9:48 PMtyeo098 says:
This is how i busted my old dell! i tried to charge my GBASP thru the USB port, I got em mixed up and the computer detected it and said: "Power surge on Usb Hub" It didnt work anymore. I fried the USB 5v PSU chip on my mobo, so a 600$ comp didnt work because a 20c part was fried. It sucked.
Feb 22, 2008. 8:12 PMGorillazMiko says:
Heh, this is really cool and awesome and easy to do.
Pretty cool, but I most likely will not try this out.
Feb 22, 2008. 4:35 PMry25920 says:
This would work fine for for 2 or 4C batteries, right?
Feb 22, 2008. 3:59 PMtheRIAA says:
this won't break your power supply, but it WILL WEAR IT OUT SOONER
Feb 22, 2008. 3:30 PMironsmiter says:
I suppose, if you want to risk blowing something important in your PC, go for it! :-) Personally, I'd think hacking a wallwart charger to do this would be faster, and safer. For your computer. Wallwarts - $5, Highend PC - $1500 you do the math :-) having the spring probably helps. "real" hot wire cutters(used for cutting foam for modeleing, etc) ususally use nicrhrome wire or panio wire. Mine uses an old space heater element, unwound while hot.
Feb 22, 2008. 2:30 PMKiteman says:
So, you're shorting out the USB socket? Is that healthy for the computer?
Feb 22, 2008. 2:51 PMPocketSized says:
I would have to agree.
As a rule of thumb I try not to short circuit anything (always seems safer that way).
You are taking the unnecessary gamble that your USB interface has some sort of current limiter.
There are projects concerning how to make wire hot enough to cut things, usually named 'foam cutters' (there is probably a more accurate name).
I've been considering making one, but I would prefer to make one safe in the knowledge that I know exactly what I am doing, other than simply short circuiting electric terminals.
Feb 22, 2008. 2:36 PMkillerjackalope says:
The Os shuts down the socket in the event of a power surge, I was going to make one of these but slightly more powerful, also axpect to see a diy coffee heater/drink cooler coaster soon enough...
Feb 22, 2008. 3:34 PMBran says:
a diy coffee heater/drink cooler coaster...
Peltier device?
Feb 22, 2008. 3:52 PMkillerjackalope says:
You caught on first, it's the packaging of the device that's important...
Feb 22, 2008. 2:54 PMKiteman says:
OK - I didn't think it would harm the computing bits of your PC, I was just worried that a straight short would blow fuses or otherwise damage your power supply (which could, I suppose, have knock-effects with the rest of the PC).
If you (and Killerjackalope) have been using it safely, then I guess it's fine.
Feb 22, 2008. 3:53 PMkillerjackalope says:
No i just had a couple of accidents testing projects, sometimes I accidentally short the port and the message comes up, the port is shut down until you remove the item and reset the status of the port from disabled...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:dean-101
