3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB tester
USB tester
This simple device allows you to check the correct working of the USB ports of any computer, using a green led and message from your operative system.
It will allow you to test the proper assembly of any port without risking any expensive device.
If you normally work fixing computers this is a must in your tool kit.
Ps: I'm from Argentina so let me know any grammar mistake
Step 1The circuit
The circuit
The circuit is very simple using only some discrete components.
The operation is simple, you connect it to the USB port, if it's okay, the green LED is lit in all its intensity and you will have a message from your operative system telling you than a USB device has been detected. If the polarity is reversed the red LED is lit in all its intensity. Any other combination causes lit one of the two LED but very dim.
You will need:
The PCB (see step 2)
The USB connector (see step 3)
Two 22K resistors
One 1k resistor
One 100 ohm resistor
One 1.5 k resistor
One 3v3 zener diode
One 1N4148 diode
Two leds (green and red)
The diagram was extracted from this forum (in Spanish): http://www.ucontrol.com.ar/forosmf/proyectos-en-general/probador-usb/
77 comments
1-40 of 77next »
Nov 16, 2011. 10:33 AMm1s73r says:
When does the red LED light up?
Nov 1, 2010. 2:15 PMbobbock says:
What wattage resistors are you using, or does it make a difference?
I'm new to building electronic devices, and thought this would be a good one to try. When I went to get the supplies from my local store the first question they asked was what wattage. I bought 1/4 watt ressistors assuming that the voltage of a usb port is around 3.3 volts.
Thank you for the project and any help you can give.
Nov 8, 2011. 3:35 PMionic says:
Bob
I believe they are 1/8W as they are the same size as a 1N4148 diode.
Jul 12, 2011. 6:52 PMBlip-Blip-Duino says:
Wattage(sounds like cabbage, haha) doesn't really make a difference. In this case, seeing as you're using an USB port, with 1/8 you're more than fine. BTW USB uses 5 volts DC, usually @ 200-450 mAh.
Aug 7, 2011. 5:03 PMos_sanches says:
kkkk, muito bom.
Jul 15, 2011. 12:34 AMjupiter2 says:
good job!
May 6, 2011. 3:54 PMbeaver84 says:
cool! :D
May 5, 2011. 2:17 AMinhaos says:
your schematic is cool
here is a perfect solution for you
http://www.inhaos.com/product_info.php?products_id=29
cheers!
Mar 17, 2011. 10:37 AMmased007 says:
Hello. How to ironing method do? please
Feb 12, 2011. 8:39 AMMoritzB says:
Does it only check the voltage at the red and black connections, or does it also check the data lines?
Jan 26, 2011. 6:07 PMdwyatt1045 says:
I was wondering what the wattage is for the resistor
Dec 1, 2010. 10:15 AMkenobr100 says:
how much did this cost to build ?
Aug 20, 2010. 9:52 AMxtagz says:
Sir.. Can u send me some other links for the PCB design..?? i cant DL the pdf file because im not a pro members... thanks..
Nov 17, 2010. 3:18 PMMinifig666 says:
You don't have to be a pro to get that PDF, did you try clicking it?
Sep 29, 2010. 11:38 PMmanish_1october says:
manish_1october@yahoo.co.in
i need a circuit diagram.
can u help me.....
Oct 27, 2010. 2:28 PMTaran606 says:
i dont have any 3v3 zener diodes any other parts i can use
Aug 19, 2010. 10:01 PMhiteshp says:
Taran A Small Bridge Pack can really do the Trick if the need is only checking the Polarities ... if you know proper functioning of Diodes..
Aug 19, 2010. 12:07 PMTaran606 says:
Insted of using 5 resistors can't u use one 100 ohm resistor and one 46.5k resistor
Aug 19, 2010. 9:32 PMTaran606 says:
Why explain and can u make a smaller compact version plz
Aug 19, 2010. 9:23 PMTaran606 says:
Why explain abd can u make a smaller version that's more compact
Aug 18, 2010. 10:42 PMTaran606 says:
In the 5th pic or the last one what are the extra leeds on the side for and are they inportant
Aug 19, 2010. 11:51 AMTaran606 says:
Thanks
Aug 19, 2010. 8:13 AMhiteshp says:
Well You Could have Done it ... avoiding Most of Resitors using a Bridge Pack One Resister and Two LEDs... This is Nice though .. A Bridge would compact it further... :)
Aug 19, 2010. 10:00 AMTaran606 says:
Can I make a diagram because this one has to many resistors and I want to make it smaller
Aug 16, 2010. 5:07 PMLeuh4n says:
Fa, que trabajo posta :O
Aug 10, 2010. 9:37 AMvhhp says:
Brunoip, Good work. Liked your product and also your sensible replies. ..regards..
Jul 10, 2010. 1:24 PMMASKELF says:
excellent creation Bruno after creating it worked perfectly and as expected, is a great tool because I lost a USB memory port through a poorly connected, thanks! add a photo of mine
Jul 7, 2010. 7:49 PMozzymon says:
buenisima la idea, increible tu ingenio!!! segui asi y ojala que tenfçgas suerte con tu usb tester!!
Jul 7, 2010. 9:24 AMpapajay_23 says:
what is the introduction of this usb tester??can i use thiis in thesis proposal?
Jul 6, 2010. 1:01 PMvyncynt says:
I have been wanting to have one since I got my tech job. this is very neat, thanks brunoip.
Jul 2, 2010. 2:25 AMfpm2000 says:
Nice instructable! Since I don´t have the skills to build one, I purchased a similar device from www.USBcheck.net.
Jun 26, 2010. 8:04 AMTheGimpAddict says:
Did you design the pcb by yourself?
Jun 22, 2010. 9:55 PMzilcho says:
I'm a complete noob on electronic stuffs so could you tell me what kind of iron on thing you used to print the circuit board.
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:brunoip(Bruno Games)
Robots and video games...
