Remove these ads by
Signing UpStep 1P 1
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
1 by thingy do you mean a 5VDC battery charger, a 5VDC phone see what i mean .....the thingy is a 5VDC adapter, or transformer or power pack
2 What is the amperage of this "5VDC thingy" if its usb then it should be at least 500 nominal Ma the reasobn being a pc usb plug is rated at that and anything more might burn the usb plug(s) up any thing less and stuff may not work or could overload the plugs
3. its always (especially with Dc voltage) advisable and safer to soldier and tape or soldier and heat shrink all connections as DC voltage will kill you faster than ac dc generally carries more amperage than ac ....amps kill not volts, though it takes
Oh I almost overlooked it how far back should the wires be stripped?
You have a great idea however you need beeter and more detailed pics and you should really research trival matters like I mentioned above before ever doing an instructable on it .
3/5 stars
It's $2.00
However, as an Instructable it is somewhat lacking - photos would be a major plus, as would correct spelling and terminology so that non-English speakers can use automatic translators to read what is posted here.
(All that's needed is a quick edit - for instance, replace "ur" with "your", "5V DC plug thingy" with "5V DC transformer" or "5V DC adaptor". What are "co siding cords", and is "E-tape" actually "electrical insulation tape"?)
