loading
loading
Picture of USB wall charger
how to make ur own USB to wall plug
Step 1: P 1
Picture of p 1
get a male - female ubs cord
Step 2: Step 2
Picture of step 2
get a 5v dc plug thingy
Step 3: Work
Picture of work
cut each cord inhalf stripping the black and red cords on the USB female side then cut the white and green cords off at the same time cut and strip both cables on ur DC plug thingy attach the co siding cords and E-tape them together
make sure the dc plug is 500mA
So would that be a minimum of 500mA ? I have a 5VDC @ 2100mA adapter, would that work without damaging anything?
anything below will for sure not work. but anything over is fine, i think. dont quote me on that tho.
you are right. my charger i made is capable of 6 A continous. and 12 A peak. even my flip phone charged just fine. this is why when you twist in a lightbulb into that 15-20 Amp socket, it dosen't explode. any usb device by spec will only draw as much amperage as it was designed to handle. (they should be self regulating)
Thank you
5ctressl1 month ago
also, if your 5v outlet is above 500-1500 mA, you should also short the data wires so a device knows it's not possiby a pc and must be a dedicated charger. this way your device will draw a higer amperage and therefore charge faster!
rayfalcon5 years ago
ok first things first no offense I am doing you to help you. with that being said its not called"E-tape" its electrical tape what if a kid or teenager where to see this and try it be as specific as possible as they dont always know our fancy terms. and the "5 VDC thingy" 3 major thingies wrong here...
1 by thingy do you mean a 5VDC battery charger, a 5VDC phone see what i mean .....the thingy is a 5VDC adapter, or transformer or power pack
2 What is the amperage of this "5VDC thingy" if its usb then it should be at least 500 nominal Ma the reasobn being a pc usb plug is rated at that and anything more might burn the usb plug(s) up any thing less and stuff may not work or could overload the plugs
3. its always (especially with Dc voltage) advisable and safer to soldier and tape or soldier and heat shrink all connections as DC voltage will kill you faster than ac dc generally carries more amperage than ac ....amps kill not volts, though it takes
Oh I almost overlooked it how far back should the wires be stripped?
You have a great idea however you need beeter and more detailed pics and you should really research trival matters like I mentioned above before ever doing an instructable on it .
3/5 stars
gamer7 years ago
tape!!!! um, maybe suggesping solder, but...
not evereyone knows how to solder tho- plus tapes fine just aslong as it stays there
Phoghat7 years ago
All I had was a RS 6.5V charger laying around, so I added a 5V regulator and it works for me.
is it possible to just get a normal wall adapter and just add enough resistors until its 5volts?
Where did you get the regulator?
dasarp7 years ago
I don't get the low rating, how much clearer can this get?
oddie12127 years ago
This might also be a helpful inscrutable to those who use portable USB hard drives and have limited laptop USB ports... plug the power into the transformer and the other into the laptop (of course) which sparks an idea... wonder if my blackberry charger could be a power port....
ya.
What? I'm not even sure "ya" is a word. This could do with some pictures and terminology, nice idea though.
ya
maulz (author) 7 years ago
ok those corrections would b nice but this isnt the most epic instruct able ever this is for the kid with a phone charger, usb cable, tape and somthing to cut with
Kiteman7 years ago
A useful idea, especially for those of us with old PCs and few USB sockets (which are all around the back of the box). Could it be adapted to have several USB sockets in parallel?
However, as an Instructable it is somewhat lacking - photos would be a major plus, as would correct spelling and terminology so that non-English speakers can use automatic translators to read what is posted here.
(All that's needed is a quick edit - for instance, replace "ur" with "your", "5V DC plug thingy" with "5V DC transformer" or "5V DC adaptor". What are "co siding cords", and is "E-tape" actually "electrical insulation tape"?)
Ezza7 years ago
Nice,
