USING SYSTEM RESTORE
647
4
Posted in TechnologyMicrosoft
Introduction: USING SYSTEM RESTORE
About: im klaus and i am a computer nutcase ohh and im single HINT HINT
System restore first appeared in windows me, and it gives you the opportunity to return your pc to a state in which it was working in a satisfactory manner,
Therefore undoing things that may have caused problems.
Step 1: USING SYSTEM CHECK POINTS
First go to the start menu, and then chose all programs, accessories, ad finally system restore
## Restore the restore&. ##
## If you perform a restore ##
## And are not happy with ##
## The results, you can ##
## Always revert back to the ##
## Stage from which you ##
## Preformed the restore! ##
Step 2: CHOSING a RESTORE POINT
You have 2 choices here. The first is to restore to a time that has been determined by your computer, or you can create your own restore point.
If you have a problem with your pc at the moment, select the restore my computer to an earlier time radio button and then click on next at the bottom of the window.
Step 3: CHOSE a DATE
A calendar appears. In the below example, no restore points have been created by the user - only system checkpoints are available these are shown as slightly bolder numbers in the calendar.
To restore your computer to one of these dates, click on the number and then the next button.
Before you continue, you will be asked to make sure you don’t have any applications open at this time. When you are ready, click the next button.
Your computer begins the restore routine, which will take a wile, your computer will then automatically restart.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    3 Comments
    my computer has an error and wont even turn on, how do i fix i.
    I would suggest that you don't trust System restore blindly, since I've experience that when I really needed it, it did a "Computer says no".
    I recommend also using a free partition backup utility like one of these:
    http://download.cnet.com/Macrium-Reflect-Free/3000-2242_4-10845728.html
    http://download.cnet.com/Paragon-Backup-Recovery-Free-Edition-32-bit/3000-2242_4-10972187.html
    This was such a blessing to me once. MacAfee did an auto-update, and deleted all of my songs/photos/documents. I almost cried. :(
