3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
UV LED Solar Light Modification
  • last photo ←
Change a yellow or white light solar path light to an Ultra Violet Path Light.
Step 1Take a solar path light and remove the top from the clear globe
--DO NOT look directly into a UV led when it is on...EVER. UV light is dangerous to unprotected eyes so throw on a pair of UV blocking sunglasses for this project--
Take the top off the solar light and place it on your workbench solar cell side down. This should cause the led to light up and shine into your face. If it is not on figure out where the photo cell is and tape over it to trick it into thinking it is night. You will need to have the light ON. When you have the light on use your wire cutters and snip off the LED.
15 comments
Feb 28, 2012. 7:19 PMsunspirit says:
I'm wondering what the uv led rating was. Most small solar landscape lights run on 1.2v to 1.4 volts from the battery. Is a 1.2v to 1.4v uv led available anywhere for purchase? I'm interested in trying this but that is one piece of information that was left out of the directions. Most of the uv led's that I can find are powered by 4volts.
The ideal uv led is 365 nm. I found a 405-365nm but again, it's forward voltage was 3.5 volts.
Can anyone assist? Thanks,.
Sep 7, 2011. 12:25 PMjohndean2 says:
The UV glow will be much brighter than the traditional outdoor lighting and will prove to be much better. I am not sure if it will be good on the eyes though at night, but as long as you don't look into it you should be fine.
May 2, 2009. 10:40 AMthekanester says:
Great idea. And I say that because I bought a bunch of bits for making a UV sunjar, with orange UV paint (because my wee boy's fave colour is orange). I'm also scooping the bits from a £1 garden light and so far it's going well. I'll post an instructable on here when it's done...Good job! I thought I was the first person to do this on this site, however.
Jan 24, 2010. 7:42 PMyyyoshiii says:
 im confused about the 'paint something white' part of your instructions. so, could you put a pic of how u painted the inside of a jar with this stuff (if you did it at all)
May 24, 2009. 6:37 AMpolonium9 says:
would i be able to use this as a rechargeable battery for my digital camera? or would something go wrong. please write back because i am very curious and want free battery power from solar!!
May 25, 2009. 3:13 PMpolonium9 says:
i will hopefully buy 2 of these, that way i could get free energy for my camera. but do the NiCd batteries heat up and may explode if used in a digital camera?
Nov 26, 2009. 2:36 PMEvilthingamabober says:
Not unless they are the wrong voltage or are shorted out.
Dec 28, 2008. 6:44 PMFullyInvolvedScientist says:
Really cool idea! Great instructable and I am going to check out that paint.
Oct 19, 2008. 6:28 AMLinuxH4x0r says:
I should do this, but leave in the normal light. Scorpions glow under UV and this would make it safer to walk at night
Dec 28, 2008. 6:42 PMFullyInvolvedScientist says:
The normal light would work good for the glow but, this week I worked with some glow paint and UV LEDS and that combination seemed to make the "glow" brighter and last much longer. At least that it was it seemed to me. That is a great idea about the scorpions too by the way.
Nov 2, 2008. 5:30 PMac7ss says:
Good idea, this glow product will maintain a visible light long after the lamp goes dark, making this light actually useful long into the night.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:spacehead
