UV Maglight
Introduction: UV Maglight
Here's how to transform a regular maglite into a UV maglite using a LED. This is a very easy Instructable and may cost only a few dollars.
Step 1: You Need...
~Needle nose pliers
~Wire cutters
~Mini MagLite
~1/4 in drill bit
Step 2: Disassemble
Disassemble the MagLite
Step 3: LED
Resise the led's leads with pliers and hands
Step 4: Drill
Drill the hole wider and make sure the LED fits through easily
Step 5: Reassemble
Insert the led into the holes and it doesn't work, switch the leads around. Then reassemble the light together.
Step 6: Now You Are
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    I grabbed the led from my local radio shack and followe but the uv led seems to lack any real brightness, i have a standard mini mag led flashlight x2 AA
    Led are
    Wavelenght 405nm typ
    Viewing angle 20 degrees
    Fw current 20mA
    Fw supply 3.3V typical 4.0V max
    Any ideas to help would be great email me at oxstien@gmail.com or here i dont know if it will notify me of replies
    took me about 15-20 minutes to do this conversion, and it works great. My UV maglite will be a part of my toolbox now.. ready to spot leaks in the A/C
    Radio Shack has the UV LED. It is part #276-0014, and is in the LED parts bin. $1.99 for 2 LED bulbs.
    I would recommend that when you drill out the reflector, you do it with gradually larger bits until you get to the final bit size of 7/32, that way you avoid cracking the plastic reflector housing. Take care in not cutting the leads of the LED too short so that it will fit through the bulb mounting plate and into the flashlight terminal leads.
    Awsome, where do you get a UV LED though?
    In the netherlands I can buy them at the baco 10 for a few euros.
    radioshack read the other posts
    so will this light kill germs like the UV wands?
    UV light from usual UV leds is not good for killing germs. You can look it up on google, it's very hard to do a LED with the right frequency (deep uv) for killing germs, but once it is easily doable, it will make UV "cleaners" much more cheaper.
    That's cool but can you give the tech specs for the LED?
    Radio Shack
    High visibility, T-1 3/4 (5mm)
    Intensity: 280mcd (typical)
    Wavelength: 395nm (minimum), 410nm (maximum)
    Viewing angle: 30°
    FW current: 20mA;
    FW supply: 3.2 (typical), 3.8V (maximum)
