UV Printed and Laser Engraved Laptop
1,643
14
4
Published
Introduction: UV Printed and Laser Engraved Laptop
About: Trotec Laser Canada provides laser engraving and laser cutting machines for processing a wide variety of materials. Cut, engrave and mark wood, paper, metal, acrylic, leather, stone, plastics and many more. ...
Look at the pelican fly! Today we're UV printing a laptop cover and laser cutting our TroLase engraving material to glue on top. We're using a Mutoh ValueJet 426 UV printer and a Trotec Speedy 100 laser engraving machine.
Step 1: Prepare Artwork
You can use either the Adobe Illustrator or CorelDraw file attached. You can adjust the size of the artwork according to your laptop size.
Step 2: UV Printing the Laptop
We first place the laptop at the bottom right corner of our UV printer. We make sure the laptop is flat, and focus it using the focus bar. We then set the inks to CMYKW (variable dot), the W is for the white. In the "White Options" we set the White to under-colour. This way the printer will automatically print a layer of white first and simultaneously place the colour layer with every pass. We want the white on to make to regular colours more vibrant.
Step 3: Laser Engraving
We then put our laptop into our Trotec Speedy 100 laser engraving machine and start engraving the fill colou,r from the artwork file, directly onto the laptop. If the laptop was a metallic/aluminum finish we can leave it as is and have the bright silver as our artwork. Because it's casing is black we will add a layer of red TroLase plastic with a 3M adhesive backing on top in the next step.
Step 4: Laser Cutting the Top Plastic Layer
We then use our 1/32" TroLase Red/White plastic with 3M adhesive backing. In the artwork file, the top layer is outlined with a red hairline (thinnest line in Illustrator) for the cut line. We use that to make a kiss-cut on the plastic material.
Step 5: Peeling and Glueing the Top Layer
The reason we do a kiss-cut is because we don't want to cut through the adhesive backing. This way it's easier to just peel our top layer from the adhesive and then glue it onto the laptop.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    4 Comments
    Haha, this is a weird coincidence. I was just watching War Dogs last night and they had a Scarface poster on the wall. Great work :)
    I don't understand the UV printer. I don't know anything about them. Did you print directly on the laptop?
    Hi William, yes exactly you can print on any surface basically. It's ink that's cured with UV light as soon as it touches the surface.
