This Instructable is for a high power flashlight that uses a CREE XM-L LED and is powered by 3 D-cell batteries. Most of the parts are fabricated using a 3D printer and due to the size/shape, it is broken down into several segments. The wiring for this flashlight is very simple. It composes of the 3 batteries in series, connected straight to the LED via a rocker switch. There are no resistors in series due to the fact that there is enough resistance from the batteries (alkaline), wires, and switch.. and because the CREE XM-Ls are beastly LEDs. Granted, this is a very inefficient way to power these LEDs for various reasons, but it does work and is really bright... battery life might just be a bit lacking... and the light output may be a bit inconsistent from beginning to end of battery life. The middle segment of the body is sized to be the length of a D-cell battery so one can add extra segments to make it a 4+ battery light. This will of course require different wiring/electronics... not covered in this Instructable.
Step 2: Print UL1000 Components
Tools/Materials needed:
2. LED Cap
Raft: No
Reason: Sometimes the raft will peel off the first couple of layers in the print.. This piece has fairly strict tolerances (don't want LED lens to be too loose or too tight).. so I leave the raft off. Sometimes the ends curl up, but they push back flat when fastening to the heat sink.
5. Body End Segment
Raft: Yes
Reason: Reduces the "mushrooming" of the bottom of the print. Without raft, you are likely to have a ridge at the end segment to end cap splice.
UL1000 LED Lens Bushing.scad319 bytes
UL1000 End Cap.scad994 bytes
UL1000 Body Mid Segment.scad887 bytes
UL1000 Body End Segment.scad954 bytes
UL1000 Lens Bushing.stl327 KB
UL1000 End Cap.stl827 KBStep 3: Prepare LED module
Step 1: Strip/tin 1/4" of one end of each wire
Step 5: Turn on stove to medium heat and place thermal pad in frying pan/skillet. Watch closely and remove thermal pad when the solder paste melts. Depending on what types of solder/solder paste you use, you may be able to use the melting of the regular solder as an indication that the solder paste is about to melt.
Step 4: Assemble flashlight head (heat sink/LED module)
Step 9: Place lens optic over LED in the hacked up case pieces.
Step 5: Prepare positive circuit wiring
Step 7: Prepare/install end cap
Step 8: Appendix A: Extra information
Battery contacts.pdf123 KB
Heat sink.pdf215 KB
XLampXM-L.pdf794 KB
Duracell MX1300.pdf92 KB
Energizer e95.pdf65 KB
Visit Our Store »
Go Pro Today »
very well done!
The trickiest part for me to find was the rocker switch. You can find them on Mouser.com if you search for "R13-133" (and get the datasheet) but you have to buy them in multiples of like 1000 from them... Although not labeled the same, I found the same switches on Amazon.com:
http://www.amazon.com/JT-Products-2703-2J-Illuminated-Rocker/dp/B002UZW77C/ref=sr_1_9?ie=UTF8&qid=1330992687&sr=8-9
I think I also found them on http://www.parts-express.com.. but I ended up ordering from Amazon because I love amazon prime. Unfortunately, I haven't been able to find the plain unlighted versions, but I know they exist..
The XLamp XM-L LED is the
industry’s highest performance,
single-die white lighting-class LED.
The XLamp XM-L is 20% more
efficient than the XLamp XP-G at
the same current, and can deliver
1000 lumens with 100 lumens per
watt efficacy.
Even if you only achieve half of that, 500 lumens is insanely bright.
Have you looked at the forward voltage and current on an oscilloscope with a fresh set of batteries? I wonder if the peak current and voltage exceeds the recommended spec max of 3000mA and 3.35V?
I was wondering though, why not resistors? Wouldn't that increase the batter life (with i've gathered to be a little poor). Maybe a pot to make the brightness adjustable?
I didn't use resistors because I wanted it to be as bright as possible with no regard for battery life or consistency.. and because it was simple and easy..
@Demonic69 - i just got 3 of these LED's in the mail with some 18650's... I normally make headlamps, but a flashlight version would be fun too.
BTW, you had mentioned in the instructable that this isn't very efficient. It is actually the MOST efficient way to drive an LED since there is no power conversion loss, but with the downside being if you had used a lesser LED it might damage it, and the voltage depression issue mentioned above + voltage/current relationship so it won't be consistent brightness.
The test would be...if the battery lasts for 1-2 hours at good operation, then you're not abusing it *too* much (0.5-1 "c"), but if it lasts for only <1 hour, then you'll be getting a lot less capacity out of the battery than you could otherwise.
Also, JB epoxies claims to be a good thermal conductor, so if you want to attach something to a heat sink, JB epoxies are a good option instead of thermal paste and screws.
It would be good to compare them to a dedicated product like Arctic Silver adhesive, or even double-sided thermal tape.
Things to watch for: keep the application of it thin as possible as the stuff its gluing together has a MUCH higher conductance, and its expensive so excess is just waste. The thinner it is, the less resistance from the stuff regardless of its coefficient. Also, once set, this is an epoxy, so it will not move, make sure you put the parts together correctly!
Thermal conduction is not a matter to be taken lightly. Never substitute an epoxy not specifically designed for high thermal conduction if at all possible. Otherwise there is excessive heat and or excessively large/heavy/expensive heatsink needed to compensate for the wrong thermal interface material.
Also potting electronics is not the primary thermal path for anything specified to need heatsinking (just wanted to clarify this in case anyone got the wrong idea).
Lastly, JBWeld cures to a granular brittle structure, it is not the right formulation for anything with a different coefficient of expansion or subject to possible impact like a flashlight that might be dropped.
I agree Arctic Adhesive is a good choice, or for larger area applications it is more economical to buy a tube of one of the various brands sold for use on peltiers.
I would only suggest a small change.
To use BHCS's to replace the SHCS's on the business end. They'd present a much cleaner look.
Again, very nice job!
http://www.instructables.com/id/Build-a-Laser-3D-Printer-Stereolithography-at-Ho/
check that out... maybe that can answer you
http://reprap.org/wiki/RepRap
I am thinking of making a scaled up CNC router version of the Prusa Mendel, in which case, there will most likely be an instructable for it..
It sounds like version 2 will definitely be rechargeable (with 18650s) and water resistant.. A fan would be kinda pointless on a sealed design, but it could be a cool mod for the open design.
I wonder how much work it would take to make this waterproof?
If you need a tester for a WP version I'll happily volunteer to try it out at 30m or so :D
Would also be great to see it running on 18650 cells, at 3.7v each I reckon you could get a good runtime!
If i ever get my hands on a 3d printer I'll definitely give this a go, brilliant work.
- Sealing plate between heat sink and body head
- O-ring between end segment and end cap
- Silicon around the toggle switch.. and most likely a different switch type
- Silicon/hot glue around the LED/thermal substrate
I like the idea of using 18650 cells... I'll do some thinking on that and get back to you... Also, if you want to design/draft a waterproof mod or 18650 cell mod (preferably in OpenSCAD)... I'll print a body for you. Just make sure to provide room for some control circuitry...
